3d View: Edit Weights
Closed, ArchivedPublicPATCH
Project: Blender Extensions
Tracker: Py Scripts Upload
Blender: 2.54
Category: 3D View
Python: 3.1
Script name: 3d View: Edit Weights
Wiki page: ?
Author(s): Gabriel Beaudin (Gabhead)
Status: Closed
features:
-Display the weights of vertices for the active vertex group using a vertexColor
and the weight ramp
Note:Add a vertex color channel so this won't break existent Vertex Colors ch.
-Add Absolute weight and normalyse
-OffSet Current weight and normalyse
-easyAccess to select more and Select less
hi, scripts should start in upload.
I've moved tio Upload,
the script will be reviewed then possibly moved to contrib & our svn
thanks you...
I must admit i don't really understand were to upload the scripts or how to update them. For instance AlignTools are now 11 verision ahead of the one implemented to blender.I downloaded SVN, do I need to use it to update my scripts?
By the way thanks for all your great work Brendon.I really like your Dynamic menu and all that...Happy 2.54
-gab
Hi,
can you prepare a wiki page with a bit of a manual about how to
use this?
I'd help the review process for sure :)
See
http://wiki.blender.org/index.php/Dev:2.5/Py/Scripts/Guidelines/Addons
Thanks!
Hi,
Just a Reminder for people to Join the Mail List.
If you have not already, please visit this page:
http://lists.blender.org/mailman/listinfo/bf-extensions-cvs
& join the list.
it seems these features are in Blender now.
marking as broken, then may close soon.
Hi,
Due to changes to the api including the merging of bmesh, several addons are outdated.
Please, if you are the author of an addon check your script with blender revision 44256 or newer.
That is builds made After blender 2.62 official release.
I would ask that updates be made to your addon before the Blender 2.63 release.
6-8 weeks away.
This allows time for the api to become more exposed & bmesh to stablize furthur.
If you need help, drop into irc freenode #blenderpython or #blendercoders & feel welcome to ask questions.
At the time of 2.63 release, scripts that are not repaired or in active developement will have their tracker page marked "Closed"
this will not affect your links to the tracker, similar to closing scripts in 2.49b, the page will be still availible & can be re-opened.
Thanks for your understanding & patience during these Exciting Times.
Brendon.
hi,
Currently I'm still unsure of the working state of this addon.
I'm closing this page for now. as part of 2.63 cleanup.
If you want to resubmit your addon please let me know & this page can be reopened easily.
Thanks for your addon & interest in Blender.
Brendon.
Brendon Murphy (meta-androcto) changed the task status from Unknown Status to Unknown Status.Apr 16 2012, 9:49 AM
