No blend file required.
Example:
Typed filename of "uvlayout" results in two files being created.
uvlayout.png 0 KB
uvlayout.png0001.png (Correct filesize, and this is the file with the actual image.)
Typed filename of "uvlayout.png" results in same.
WinXP
Build 32756
Thanks!
re-opening, r32803 must have fixed one instance but the file moving/renaming problem could be caused by some other error.
Can you paste the path that you save to?
looks like this file fails to get moved.
I can also look into writing to this path directly rather then renaming.
Hi Campbell
Sorry but do I understand this right?
Do you want a path like for example c:/folder1/filder2/saved.png?
I used a lot of different file save locations it is always the same. There are 2 files.
I tested it now under Ubuntu 10.10 and here it works well, only one file. So it looks like as it is only a problem on Windows.
Heiko, something like "c:/folder1/filder2/saved.png" yes.
It is very strange that a file can be rendered too but not renamed.
However I worked around the problem by removing the renaming, so just test with a build after r33105 and it should be fine.
