Adding the path to an image Editor in the file preferences window messes up the path
For example if I try to add GIMP as the image editor and go to the appropriate directory - when I push accept the image editor has this in the text bar:
//..\..\..\..\Program Files\GIMP-2.0\bin\gimp-2.6.exe
when it should be C:\Program Files\GIMP-2.0\bin\gimp-2.6.exe
I manually change it - but if left alone it won't work...
I'm running vista 32 bit...
This has been happening for a while...
You have relative path checked. Go to the User Prefs. File Settings, and uncheck Relative Paths.
Ah that fixes it. But shouldn't the image editor path be non-relative as default? I can understand why the other ones would default to relative - but image editor path doesn't seem to make a lot of sense... I could see a lot of new people to blender being confused as to this functionality...
user preference paths now default to relative disabled.
r32882.
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Resolved.Nov 5 2010, 7:33 AM
