NTB lenovo (IBM) T61, Win Vista 32b, Blender 2.55 Beta. Rendered scene OK, application crash after F3 (Save Image). So I am not able to save the result to a discrete bitmap file.
Tested your file and it works ok for me on 64bit linux.
Many of these crashes are not related to saving but the file browser and image preview code.
Can you check with a recent build of blender? - after r32956.
If this still crashes, can you give more details.
- Does this crash when the file browser opens or when you press on the save button.
- Does the format make any difference, PNG/TGA/JPEG etc.
- Can you redo this on any other system.
Hi, sorry for the question (I am not so familiar with such this project) - where I can obtain the newer (r32956) build of Blender 2.55 for Windows to try the F3 functionality?
More info:
- the crash occures just after F3 pressing (so rendering into Image Editor and/or New Window works fine)
- the format used makes no difference (PNG/JPG/BMP)
- actually I cannot test this on any other system :-(
Oops - sorry :-) just "Get Blender Beta...". Works fine (r32738). Thanx, you may close this case.
I wonder what the original version was with which you tested. Blender 2.54 beta? Assuming this is the case, and closing the report.
Yes, it was the case. Sorry for my bad input data (Blender version) - I did not check the splash screen prior bug reporting.
