Zoom oddity in camera-view
Closed, ArchivedPublicTO DO
Here a aa.blend (made on Windows XP Pro SP3 with 2.56a, containing some of my exercise-tests.
All regular known zooming methods function as described and expected. With one strange exception: when in camera-view, CTRL-MMB-drag DOES NOT ZOOM.
Scrolling the wheel, +, -, do zoom. And SHIFT-MMB-drag does pan ...Why the exception?
One of its objects is a "Cubefrom plane". It was indeed made by Z-extracting a plane. I was able to change its name but find no way to change the name of its mesh accordingly. Has it to stay "plane" ? My fault of course...
I might mention one other issue, which is certainly not a bug but rather a request. Only the color of face-surface-figures can be set. I think it might be usefull to make it also possible to set colors for edge-lengths and angle-degrees. Let me go even one question further and ask for sums of surfaces and lengths... Also for UV-seams and surfaces? :-))
Nobody (None) edited a custom field.Jan 9 2011, 5:39 PM
Nobody (None) attached 1 file(s): F15757: aa.blend.
Well this has just not be coded :) things dont work automatic! And, since almost all mouse devices have scrollwheels, thats a bit of default we do implement.
Names of objects and meshes can be set in properties editor, using the right tabs...
Ton Roosendaal (ton) changed the task status from Unknown Status to Unknown Status.Jan 9 2011, 6:56 PM
