compositor bug *NEEDS INFO*
if i change the scene into default i go to the compositor and add a composit node and try to move it blender die, im runin on geforce 9800 gt window7 x64 tkx
I loaded your blend file, but I cannot change "scene to default"... what is that?
I just set the main area to be node editor, choose the composite button, set it to "use nodes" and I can move these nodes fine with hotkey G.
Please provide more details what actions cause an error precisely with your .blend?
I'm cleaning tracker now. Report gets closed, but assigned to me. If you reply here I'll answer and investigate further.
Ton Roosendaal (ton) changed the task status from Unknown Status to Archived.Jan 25 2011, 5:32 PM
