Plus sign behind object tools moved
Closed, ArchivedPublicTO DO
If you hide the Toolbar (T), the little plus sign is off its actual position where it once was.
In releases 2.55, 2.56 and current svn this shows on the same location for me. (default startup)
But, this visualizing method is on our todo to recode better, I also have several reports where the icon draws completely on wrong place, or not even.
Ton Roosendaal (ton) changed the task status from Unknown Status to Unknown Status.Jan 25 2011, 2:05 PM
I tried two different OS (Ubuntu 10.10 and Windows 7) and the icon is off in both. If I remember correctly it was in its right position in either 2.54 or 2.53.
Well; provide a screenshot of where this showed in default startup for 2.54 and 2.56?
Also make sure you use the builds from blender.org.
ok thanks, is minor glitch, bad code...
