UI Inconsistency: No Warning when Clicking File > New
Closed, ArchivedPublicTO DO
When clicking File > New, the .blend file resets without giving a confirmation or warning.
The keyboard command for the same action (Cmd+N) asks for confirmation.
How to repeat:
1. Make a scene.
2. Forget to save it.
3. Click File > New.
4. Have a sad.
Praise: I love Blender and everyone who contributes to it. Thank you for your hard work.
= Blender 2.56 (sub 0) System Information =
Blender:
version 2.56 (sub 0), revision 34076. Release
build date: 2011-01-05, 19:24:21
platform: Darwin:64bit
binary path: /Users/ronproctor/Downloads/blender-2.56a-beta-OSX-10.5-x86_64/blender.app/Contents/MacOS/blender
build cflags: -pipe -funsigned-char -m64 -DGHOST_COCOA -DUSE_QTKIT -DPARALLEL=1 -DWITH_QUICKTIME -DUSE_QTKIT -DPARALLEL=1 -isysroot /Developer/SDKs/MacOSX10.5.sdk -mmacosx-version-min=10.5 -arch x86_64 -pipe -funsigned-char -m64 -fopenmp -O2 -ftree-vectorize -msse -msse2 -msse3 -mfpmath=sse -march=core2 -mssse3 -with-tune=core2 -enable-threads -O2 -ftree-vectorize -msse -msse2 -msse3 -mfpmath=sse -march=core2 -mssse3 -with-tune=core2 -enable-threads -m64 -fopenmp -DGHOST_COCOA -DUSE_QTKIT
build cxxflags: -isysroot /Developer/SDKs/MacOSX10.5.sdk -mmacosx-version-min=10.5 -arch x86_64 -pipe -funsigned-char -m64 -fopenmp -isysroot /Developer/SDKs/MacOSX10.5.sdk -mmacosx-version-min=10.5 -arch x86_64 -pipe -funsigned-char -m64 -fopenmp -DGHOST_COCOA -DUSE_QTKIT -O2 -ftree-vectorize -msse -msse2 -msse3 -mfpmath=sse -march=core2 -mssse3 -with-tune=core2 -enable-threads -m64 -fopenmp -DGHOST_COCOA -DUSE_QTKIT
build linkflags: -mmacosx-version-min=10.5 -Wl -isysroot /Developer/SDKs/MacOSX10.5.sdk -arch x86_64 -fexceptions -framework CoreServices -framework Foundation -framework IOKit -framework AppKit -framework Cocoa -framework Carbon -framework AudioUnit -framework AudioToolbox -framework CoreAudio -framework OpenAL -m64 -framework QTKit
build system: SCons
Python:
version: 3.1.2 (release31-maint:85925, Nov 24 2010, 12:12:09)
[GCC 4.2.1 (Apple Inc. build 5664)]
paths:
/Users/ronproctor/Downloads/blender-2.56a-beta-OSX-10.5-x86_64/blender.app/Contents/MacOS/2.56/scripts/addons
/Users/ronproctor/Downloads/blender-2.56a-beta-OSX-10.5-x86_64/blender.app/Contents/MacOS/2.56/scripts/keyingsets
/Users/ronproctor/Downloads/blender-2.56a-beta-OSX-10.5-x86_64/blender.app/Contents/MacOS/2.56/scripts/io
/Users/ronproctor/Downloads/blender-2.56a-beta-OSX-10.5-x86_64/blender.app/Contents/MacOS/2.56/scripts/op
/Users/ronproctor/Downloads/blender-2.56a-beta-OSX-10.5-x86_64/blender.app/Contents/MacOS/2.56/scripts/ui
/Users/ronproctor/Downloads/blender-2.56a-beta-OSX-10.5-x86_64/blender.app/Contents/MacOS/2.56/scripts/modules
/Users/ronproctor/Downloads/blender-2.56a-beta-OSX-10.5-x86_64/blender.app/Contents/MacOS/2.56/python/lib/python31.zip
/Users/ronproctor/Downloads/blender-2.56a-beta-OSX-10.5-x86_64/blender.app/Contents/MacOS/2.56/python/lib/python3.1
/Users/ronproctor/Downloads/blender-2.56a-beta-OSX-10.5-x86_64/blender.app/Contents/MacOS/2.56/python/lib/python3.1/plat-darwin
/Users/ronproctor/Downloads/blender-2.56a-beta-OSX-10.5-x86_64/blender.app/Contents/MacOS/2.56/python/lib/python3.1/lib-dynload
/Users/ronproctor/Downloads/blender-2.56a-beta-OSX-10.5-x86_64/blender.app/Contents/MacOS/2.56/python/lib/python3.1/site-packages
/Users/ronproctor/Downloads/blender-2.56a-beta-OSX-10.5-x86_64/blender.app/Contents/MacOS/2.56/scripts/addons/modules
Directories:
scripts: ['/Users/ronproctor/Downloads/blender-2.56a-beta-OSX-10.5-x86_64/blender.app/Contents/MacOS/2.56/scripts']
user scripts: None
datafiles: /Users/ronproctor/Library/Application Support/Blender/2.56/datafiles/
config: /Users/ronproctor/Library/Application Support/Blender/2.56/config/
scripts : /Users/ronproctor/Downloads/blender-2.56a-beta-OSX-10.5-x86_64/blender.app/Contents/MacOS/2.56/scripts/
autosave: /Users/ronproctor/Library/Application Support/Blender/2.56/autosave/
tempdir: /tmp/
renderer: ATI Radeon X1600 OpenGL Engine
vendor: ATI Technologies Inc.
version: 2.0 ATI-1.6.26
extensions:
GL_ARB_transpose_matrix GL_ARB_vertex_program GL_ARB_vertex_blend
GL_ARB_window_pos GL_ARB_shader_objects GL_ARB_vertex_shader
GL_ARB_shading_language_100 GL_EXT_multi_draw_arrays
GL_EXT_clip_volume_hint GL_EXT_rescale_normal
GL_EXT_draw_range_elements GL_EXT_fog_coord
GL_EXT_gpu_program_parameters GL_EXT_geometry_shader4
GL_EXT_transform_feedback GL_APPLE_client_storage
GL_APPLE_specular_vector GL_APPLE_transform_hint
GL_APPLE_packed_pixels GL_APPLE_fence GL_APPLE_vertex_array_object
GL_APPLE_vertex_program_evaluators GL_APPLE_element_array
GL_APPLE_flush_render GL_APPLE_aux_depth_stencil
GL_NV_texgen_reflection GL_NV_light_max_exponent GL_IBM_rasterpos_clip
GL_SGIS_generate_mipmap GL_ARB_imaging GL_ARB_point_parameters
GL_ARB_texture_env_crossbar GL_ARB_texture_border_clamp
GL_ARB_multitexture GL_ARB_texture_env_add GL_ARB_texture_cube_map
GL_ARB_texture_env_dot3 GL_ARB_multisample GL_ARB_texture_env_combine
GL_ARB_texture_compression GL_ARB_texture_mirrored_repeat
GL_ARB_shadow GL_ARB_depth_texture GL_ARB_shadow_ambient
GL_ARB_fragment_program GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader GL_ARB_occlusion_query GL_ARB_point_sprite
GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object
GL_ARB_pixel_buffer_object GL_ARB_draw_buffers
GL_ARB_shader_texture_lod GL_ARB_half_float_vertex GL_ARB_texture_rg
GL_EXT_compiled_vertex_array GL_EXT_framebuffer_object
GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample
GL_EXT_texture_rectangle GL_ARB_texture_rectangle
GL_EXT_texture_env_add GL_EXT_blend_color GL_EXT_blend_minmax
GL_EXT_blend_subtract GL_EXT_texture_lod_bias GL_EXT_abgr GL_EXT_bgra
GL_EXT_stencil_wrap GL_EXT_texture_filter_anisotropic
GL_EXT_separate_specular_color GL_EXT_secondary_color
GL_EXT_blend_func_separate GL_EXT_shadow_funcs GL_EXT_stencil_two_side
GL_EXT_texture_compression_s3tc GL_EXT_texture_compression_dxt1
GL_EXT_texture_sRGB GL_EXT_blend_equation_separate
GL_EXT_texture_mirror_clamp GL_EXT_packed_depth_stencil
GL_EXT_provoking_vertex GL_APPLE_flush_buffer_range GL_APPLE_ycbcr_422
GL_APPLE_rgb_422 GL_APPLE_vertex_array_range GL_APPLE_texture_range
GL_APPLE_float_pixels GL_ATI_texture_float GL_ARB_texture_float
GL_ARB_half_float_pixel GL_APPLE_pixel_buffer
GL_APPLE_object_purgeable GL_NV_blend_square GL_NV_fog_distance
GL_ATI_texture_mirror_once GL_ATI_blend_equation_separate
GL_ATI_blend_weighted_minmax GL_ATI_texture_env_combine3
GL_ATI_separate_stencil GL_ATI_texture_compression_3dc
GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SGI_color_matrix
GL_EXT_vertex_array_bgra GL_ARB_instanced_arrays
Confirmed.
Plus Blender doesn't indicate changes in unsaved file with a star in title bar.
Moving to 2.5 bug tracker
Moved from Blender 2.4x Bug Tracker to Blender 2.5 Bug Tracker
File-Open also doesn't. This is stuff for the todo to carefully examine how to tackle it.
Ton Roosendaal (ton) changed the task status from Unknown Status to Unknown Status.Mar 2 2011, 5:27 PM
