Good day, the issues are next:
1.- In the object data window when are in edit mode the function to share the same type of properties in texture face like transparency, when try to apply the copy transp the action don't have any effect, the properties don't change in any of the other faces selected.
2.- In weight mode the shortcut to select a group of faces to paint the weight (L) just select a particular group and don't select when ever the mouse cursor are.
3.- When try to set a texture to influence the tranparency (just black and white) and render the scene, the image don't show the transparency effect even show a white pixels that suppose not to be there.
The actions mentioned before was compared with blender 2.49b, where work without any problems.
Blender 2.56.0 r34076
Windows 7 professional 64-bit
Nvidia GeForce 9600 GT
Comment Actions
It is very hard to read this text. It seems to me you used translation software?
Please try to at *least* add a .blend file for each problem, which illustrates the error clearly.
Comment Actions
reply to each point
1) yes, we don't have a way to change selected faces modes at the moment, this needs to be added.
2) Weightpaint mask mode, L (cursor) and Ctrl+L (existing selection) work ok here, need a blendfile example.
3) Need a blend example of this too.
Comment Actions
Closing inactive report. I think the reporter doesn't get the tracker mails, or can't read english...
