This patch adds a theme color for loopcut selection.
I didn't want to mess with the versions so the do_versions function only checks for versionfile < 257.
I guess the reviewer should decide what to do.
Sorry, somehow missed this.
Well, since pretty much everyhing in blender has a theme color I think loopcut should have it too.
Not sure who usually decides there things but it would be up to them.
This patch won't apply to current svn of course.
Will handle this after 2.72 release (knife could also use themeable colors, at least).
Could also be a good occasion to harmonize those tools' colors!
I'm not too thrilled by the idea of adding yet more theme colors. I'd much rather see us consolidate theme colors to be much more manageable by using groups of colors. For example, Mesh Tool colors, which might include color states for:
- Active Modal Element (such as current knife cut)
- In-active Modal Element (such as previous knife cuts within the same modal)
- Etc
- Etc
Creating custom themes right now is an absolutely daunting task. Unnecessarily so. With some thoughtful planning we ought to be able to consolidate many of the colors per editor to make them much, much more manageable. Creating a theme right now involves an awful lot of repetitive work, since we often set the same colors for many different operations across different editors.
carter2422 is right.
Actually, not only loopcut and knife are concerned but also vertex/edge slide.
Actually, that was my idea when I said « Could also be a good occasion to harmonize those tools' colors! » - to only have a set of colours reused by all those tools. ;)
Rejecting for now, as the decision was made to not allow any new theme options for now and the request for reorganizing those type of theme colors needs a bit more work beyond the scope of this patch.
