Hi!
add cube
add material
add texture
set to voxel data
set file format to image sequence
now try to change the Source type with the menu
you cant select anything other than Sequence...
cheers
occurs on win7 64 with r32968 w32 from builder.blender.org
ati radeon hd4290
Comment Actions
ubuntu 10.10 rev35980
It is normal behavior because sequence of slices for voxels have to be an image sequence and not other type of source image.
Maybe Source type should be hidden in the UI.
Comment Actions
Yep, this only works for slices.
I'm not so fond of hacking in default menus all such exceptions though, rather have different ways to communicate it... needs thinking.
