The little preview that you can see in some nodes like viewer or others is lost after a Lens Distortion node
Comment Actions
I found out what is really happening, the Lens Distortion node sets the alpha to 0 in the entire image, making output renders be transparent
Comment Actions
Note that lens distortion only works doing some crazy "wavelength" stuff, ignoring alpha altogether (of course).
Best improvement I can do is to just set alpha 1.0 for the entire image. This node should be documented as such... after operation, alpha is cleared to 1.
Goes to svn now.
Comment Actions
good enough, other solution could be just pass the same unmodified alpha
anyway thanks for fix :)
