Compositor: Driver value won't trigger a redraw
Duplicates: T26764
I wanted to use a 3D object to modify values of nodes in the compositor.
1.So I set constraints to the object and
2.I added a Value Node in the Compositor.
3.I added a driver to the Value Node.
4.I pointed the Driver at the object value.
But I can't get the Compositor to update after each change (in the 3D window). However the driver value in the "Value node" does change. Other (direct node value) changes trigger a compositor redraw, just not driver values.
Sometimes Blender crashes after changing the driver value.
Windows XP pro
Intel Core2 Duo @3.33GHz
3.25GB
Probably this requires the updates being called, but the problem with these atm is that calling them gives too much of a slowdown that it's infeasible to do so.
Joshua Leung (aligorith) changed the task status from Unknown Status to Archived.Apr 28 2011, 11:26 AM
