Hello, by the guide from Campbell Barton,
I fixed the Hue flipping by applying a new algorithm.
I have compiled it and it works in my build and passed the bug file.
I can say this bug is fixed here.
And I added lots of comment on that file,
I wish it could be helpful.
Jianming Guo
Bug description
http://projects.blender.org/tracker/index.php?func=detail&aid=27510&group_id=9&atid=498
Patch revision: 36986
Tested in Ubuntu 10.10 64
Hi, could you clean this patch up a bit?, it seems to include unrelated changes.
I think the logic for this can be done with only minimal edits 2-5 lines.
I'll do it tomorrow, I just submitted my report to our professor.
I added lots of comments, I should remove it.
I thought It should be simpler too,
but it came up this complex logic probably because I have not enough programming experience
New Patch
Index: source/blender/nodes/intern/CMP_nodes/CMP_colorMatte.c
--- source/blender/nodes/intern/CMP_nodes/CMP_colorMatte.c (revision 37009)
+++ source/blender/nodes/intern/CMP_nodes/CMP_colorMatte.c (working copy)
@@ -55,7 +55,9 @@
VECCOPY(out, in);
- if(fabs(in[0]-c->key[0]) < c->t1 &&
+ if(( ( (c->key[0] + c->t1 * 0.5f >= 1 ) && (( 1 - in[0] <= (c->t1*0.5f + 1 - c->key[0])) || (in[0] <= (c->t1 * 0.5f - 1 + c->key[0]))) ) ||
+ ( (c->key[0] - c->t1 * 0.5f <= 0 ) && ((in[0] - c->key[0] - c->t1 *0.5f <= 0 ) || ((1 - in[0]) <= (c->t1 * 0.5f - c->key[0]))) ) ||
+ fabs(in[0]-c->key[0]) <= c->t1) &&
fabs(in[1]-c->key[1]) < c->t2 &&
fabs(in[2]-c->key[2]) < c->t3)
I can't use this system to upload file,
It said
"double submit" error.
Sorry about paste the content here
Thanks Tom for your fix, but I looked into this and found a simpler change, committed r37051.
--- source/blender/nodes/intern/CMP_nodes/CMP_colorMatte.c (revision 37030)
@@ -49,16 +49,24 @@
static void do_color_key(bNode *node, float *out, float *in)
+ float h_wrap;
NodeChroma *c;
c=node->storage;
VECCOPY(out, in);
- fabs(in[1]-c->key[1]) < c->t2 &&
- fabs(in[2]-c->key[2]) < c->t3)
+ if(
+ /* do hue last because it needs to wrap, and does some more checks */
+ /* sat */ (fabs(in[1]-c->key[1]) < c->t2) &&
+ /* val */ (fabs(in[2]-c->key[2]) < c->t3) &&
+ /* multiply by 2 because it wraps on both sides of the hue,
+ * otherwise 0.5 would key all hue's */
+ /* hue */ ((h_wrap= 2.0f * fabs(in[0]-c->key[0])) < c->t1 || (2.0f - h_wrap) < c->t1)
out[3]=0.0; /*make transparent*/
thanks, I hope mine provided clue for your patch.
I forgot there is a fabs(),
this one is better.
