Edges menu in mesh mode, with maya hotkeys, not working by default. 2.58
Closed, ArchivedPublicTO DO
I was going through the list of MAYA hotkeys within blender. When I tried the default hotkey for "Call menu Edges" in mesh mode which is, "Ctrl E". it doesn't work it just extrudes. But when I change the call to "Ctrl Alt E" it works. This is just for the Maya hotkey set
using a macbook pro with OSX 10.6.8 and 64bit blender 2.58a downloaded direct from blender.org
I guess that is because the default option for ctrl+e is not being cancelled out with the presets map.
The keymapping code is getting a full revision this week. I'll assign it to Brecht to check on later, and mark report as todo.
Ton Roosendaal (ton) changed the task status from Unknown Status to Unknown Status.Jul 18 2011, 6:26 PM
