Segfault on selecting UV-textured objects in 3d-view (textured solid mode).
Also happens in fresh CVS version.
Ubuntu Hoary PPC. Powerbook Titanium. ATI Technologies Inc Radeon R250 Lf [Radeon Mobility 9000 M9] (rev 01).
Logged In: YES
user_id=103
Hi,
Check the drivers for your 3d card... this is a common issue with drivers. :)
Inloggad: JA
user_id=3093
Stock Xorg install, nothing fancy... Ati does not supply closed drivers for PPC.
X Window System Version 6.8.2 (Ubuntu 6.8.2-10 20050405154109 root@)
Release Date: 9 February 2005
X Protocol Version 11, Revision 0, Release 6.8.2
Build Operating System: Linux 2.6.8.1 ppc [ELF]
Current Operating System: Linux jupiter 2.6.12 #1 Tue Jun 7 15:13:14 CEST 2005 ppc
Build Date: 05 April 2005
Before reporting problems, check http://wiki.X.Org
to make sure that you have the latest version.
Module Loader present
OS Kernel: Linux version 2.6.12 (root@jupiter) (gcc version 3.3.5 (Debian 1:3.3.5-8ubuntu2)) #1 Tue Jun 7 15:13:14 CEST 2005
glxinfo:
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_EXT_import_context, GLX_OML_swap_method, GLX_SGI_make_current_read,
GLX_SGIS_multisample, GLX_SGIX_fbconfig
client glx vendor string: SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory,
GLX_MESA_swap_control, GLX_MESA_swap_frame_usage, GLX_OML_swap_method,
GLX_OML_sync_control, GLX_SGI_make_current_read, GLX_SGI_swap_control,
GLX_SGI_video_sync, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group
GLX extensions:
OpenGL vendor string: Tungsten Graphics, Inc.
OpenGL renderer string: Mesa DRI R200 20040929 AGP 1x TCL
OpenGL version string: 1.3 Mesa 6.2.1
OpenGL extensions:
GL_ARB_imaging, GL_ARB_multisample, GL_ARB_multitexture,
GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3,
GL_ARB_texture_mirrored_repeat, GL_ARB_texture_rectangle,
GL_ARB_transpose_matrix, GL_ARB_vertex_buffer_object,
GL_ARB_vertex_program, GL_ARB_window_pos, GL_EXT_abgr, GL_EXT_bgra,
GL_EXT_blend_color, GL_EXT_blend_equation_separate,
GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_clip_volume_hint, GL_EXT_compiled_vertex_array, GL_EXT_convolution,
GL_EXT_copy_texture, GL_EXT_draw_range_elements, GL_EXT_histogram,
GL_EXT_packed_pixels, GL_EXT_polygon_offset, GL_EXT_rescale_normal,
GL_EXT_secondary_color, GL_EXT_separate_specular_color,
GL_EXT_stencil_wrap, GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_lod_bias,
GL_EXT_texture_mirror_clamp, GL_EXT_texture_object,
GL_EXT_texture_rectangle, GL_EXT_vertex_array, GL_APPLE_packed_pixels,
GL_ATI_blend_equation_separate, GL_ATI_texture_env_combine3,
GL_ATI_texture_mirror_once, GL_IBM_rasterpos_clip,
GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
GL_MESA_pack_invert, GL_MESA_window_pos, GL_NV_blend_square,
GL_NV_light_max_exponent, GL_NV_texture_rectangle,
GL_NV_texgen_reflection, GL_SGI_color_matrix, GL_SGI_color_table,
GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod
glu version: 1.3
glu extensions:
GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x23 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x24 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x25 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x26 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x27 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x28 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x29 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x2a 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x2b 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x2c 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x2d 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x2e 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x2f 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x30 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x31 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x32 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
Logged In: YES
user_id=103
Hi,
I notice this;
Maybe there's a dri upgrade?
We have one team member using linux ppc on a mac too... maybe he can find a clue. But my best guess is getting the compiler & debugger and try to find the issue. You could also check the ati linux ppc dri website...
Inloggad: JA
user_id=3093
Hi Ton!
I think you are right with the dri thing... Do you think there is a way round this (ie. patch blender) or do I have to get Xorg from cvs?
gdb produces the same output in debug build as in the release binary:
Stripped binary:
---Type <return> to continue, or q <return> to quit--- blender_2.37-1ubuntu2-cvs2_powerpc.debq
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 16384 (LWP 16590)]
Cannot remove breakpoints because program is no longer writable.
It might be running in another process.
Further execution is probably impossible.
0x0f543c54 in ?? () from /usr/X11R6/lib/modules/dri/r200_dri.so
(gdb) bt
#0 0x0f543c54 in ?? () from /usr/X11R6/lib/modules/dri/r200_dri.so
#1 0x0f543bec in ?? () from /usr/X11R6/lib/modules/dri/r200_dri.so
Previous frame identical to this frame (corrupt stack?)
(gdb)
Debug binary:
(gdb) c
Continuing.
[Switching to Thread 16384 (LWP 21482)]
(gdb) bt
(gdb) where
(gdb) quit
The program is running. Quit anyway (and detach it)? (y or n) y
Detaching from program: /home/anders/src/Blender/blender/blender, process 21482
Inloggad: JA
user_id=3093
If I turn off dri;
export LIBGL_ALWAYS_INDIRECT=true
the problem goes away but I get very poor preformance...
Logged In: YES
user_id=103
hrms... why doesn't the gbd debug build of blender not give the line in Blender? Somehow it switches to the dri thread, I like to see where in Blender the crash happens, could give a clue. :)
When I see Stefan (nick sgefant) I'll ask him to check this. He uses linux PPC too.
Inloggad: JA
user_id=3093
Using the debug build (bf-blender CVS scons built 050715) and the xlibmesa-dri-debug modules I get this:
anders@jupiter:~$ gdb program 6050
GNU gdb 6.3-debian
Copyright 2004 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for details.
This GDB was configured as "powerpc-linux"...program: Filen eller katalogen finns inte.
Attaching to process 6050
Using host libthread_db library "/lib/libthread_db.so.1".
Reading symbols from /home/anders/src/Blender/blender/blender...done.
Reading symbols from /usr/lib/libfreetype.so.6...done.
Loaded symbols for /usr/lib/libfreetype.so.6
Reading symbols from /usr/lib/libz.so.1...done.
Loaded symbols for /usr/lib/libz.so.1
Reading symbols from /usr/lib/libpython2.4.so.1.0...done.
Loaded symbols for /usr/lib/libpython2.4.so.1.0
Reading symbols from /usr/lib/libSDL-1.2.so.0...done.
Loaded symbols for /usr/lib/libSDL-1.2.so.0
Reading symbols from /lib/libpthread.so.0...done.
[Thread debugging using libthread_db enabled]
[New Thread 16384 (LWP 6050)]
Loaded symbols for /lib/libpthread.so.0
Reading symbols from /usr/lib/libpng12.so.0...done.
Loaded symbols for /usr/lib/libpng12.so.0
Reading symbols from /usr/lib/libjpeg.so.62...done.
Loaded symbols for /usr/lib/libjpeg.so.62
Reading symbols from /lib/libm.so.6...done.
Loaded symbols for /lib/libm.so.6
Reading symbols from /lib/libutil.so.1...done.
Loaded symbols for /lib/libutil.so.1
Reading symbols from /usr/lib/libstdc++.so.5...done.
Loaded symbols for /usr/lib/libstdc++.so.5
Reading symbols from /usr/X11R6/lib/libGL.so.1...done.
Loaded symbols for /usr/X11R6/lib/libGL.so.1
Reading symbols from /usr/X11R6/lib/libGLU.so.1...done.
Loaded symbols for /usr/X11R6/lib/libGLU.so.1
Reading symbols from /lib/libgcc_s.so.1...done.
Loaded symbols for /lib/libgcc_s.so.1
Reading symbols from /lib/libc.so.6...done.
Loaded symbols for /lib/libc.so.6
Reading symbols from /lib/libdl.so.2...done.
Loaded symbols for /lib/libdl.so.2
Reading symbols from /usr/X11R6/lib/libX11.so.6...done.
Loaded symbols for /usr/X11R6/lib/libX11.so.6
Reading symbols from /usr/X11R6/lib/libXext.so.6...done.
Loaded symbols for /usr/X11R6/lib/libXext.so.6
Reading symbols from /lib/ld.so.1...done.
Loaded symbols for /lib/ld.so.1
Reading symbols from /usr/X11R6/lib/libXxf86vm.so.1...done.
Loaded symbols for /usr/X11R6/lib/libXxf86vm.so.1
Reading symbols from /usr/X11R6/lib/modules/dri/debug/r200_dri.so...done.
Loaded symbols for /usr/X11R6/lib/modules/dri/debug/r200_dri.so
Reading symbols from /usr/lib/libexpat.so.1...done.
Loaded symbols for /usr/lib/libexpat.so.1
Reading symbols from /usr/lib/libXcursor.so.1...done.
Loaded symbols for /usr/lib/libXcursor.so.1
Reading symbols from /usr/lib/libXrender.so.1...done.
Loaded symbols for /usr/lib/libXrender.so.1
Reading symbols from /usr/X11R6/lib/X11/locale/lib/common/xlcDef.so.2...done.
Loaded symbols for /usr/X11R6/lib/X11/locale/lib/common/xlcDef.so.2
Reading symbols from /home/anders/.blender/plugins/texture/voronoi.Linux.so...done.
Loaded symbols for /home/anders/.blender/plugins/texture/voronoi.Linux.so
0x0f8630d0 in select () from /lib/libc.so.6
(gdb) c
Continuing.
<---- Loaded scene with UV-textured object
<---- Right click select UV-textured object in 3d view.
[Switching to Thread 16384 (LWP 6050)]
do_emit (ctx=0x1071d470, start=0, end=20, dest=0x34b6c020) at t_vertex.c:1028
1028 t_vertex.c: Filen eller katalogen finns inte.
in t_vertex.c
(gdb)
Logged In: YES
user_id=112
Hi,
There seem to be some problems with blender and x.org on PPC. Could you try getting x.org from cvs and see if the crash still happens?
Inloggad: JA
user_id=3093
Hi sgefant!
Tell me about them, I'll see if I can reproduce them on my TiBook.
Tried that, but the build ran out of space on my drive.
I also tried the daily build Ubuntu Breezy(unstable) live CD from http://cdimage.ubuntulinux.org/ - but it did not boot, so... back to square one...
By the way, I found this googling: http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=234062
is it related to this?
Logged In: YES
user_id=112
one of them is http://projects.blender.org/tracker/index.php?func=detail&aid=2587&group_id=9&atid=125
there's a workaround for it in the official 2.37(a) build, but not in CVS, so you might be able to reproduce it using either the ubuntu package or a cvs build of blender.
> http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=234062 is it related to this?
It doesn't seem to be, and apparently it has been fixed already.
The bug you reported also happens with the x.org packages from debian unstable, to me it's very likely that it's a bug in dri or x.org, as it doesn't happen with xfree86 4.3.0.
Inloggad: JA
user_id=3093
Stupid me... gdb is borked on ubuntu:
http://bugzilla.ubuntu.com/show_bug.cgi?id=4465
downgraded to gdb 6.1.1
a lot more interesting output now...
Is a workaround possible?
anders@jupiter:~$ gdb program 12793
GNU gdb 6.1.1
This GDB was configured as "powerpc-unknown-linux-gnu"...program: Filen eller katalogen finns inte.
Attaching to process 12793
Reading symbols from /home/anders/src/Blender/Bf_blender/blender/obj/linux-glibc2.3.2-ppc/debug/bin/blender...done.
Reading symbols from /usr/X11R6/lib/libXmu.so.6...done.
Loaded symbols for /usr/X11R6/lib/libXmu.so.6
[New Thread 16384 (LWP 12793)]
Reading symbols from /usr/X11R6/lib/libXt.so.6...done.
Loaded symbols for /usr/X11R6/lib/libXt.so.6
Reading symbols from /usr/X11R6/lib/libSM.so.6...done.
Loaded symbols for /usr/X11R6/lib/libSM.so.6
Reading symbols from /usr/X11R6/lib/libICE.so.6...done.
Loaded symbols for /usr/X11R6/lib/libICE.so.6
Reading symbols from /lib/libnss_compat.so.2...done.
Loaded symbols for /lib/libnss_compat.so.2
Reading symbols from /lib/libnsl.so.1...done.
Loaded symbols for /lib/libnsl.so.1
Reading symbols from /lib/libnss_nis.so.2...done.
Loaded symbols for /lib/libnss_nis.so.2
Reading symbols from /lib/libnss_files.so.2...done.
Loaded symbols for /lib/libnss_files.so.2
0x0f9950d0 in select () from /lib/libc.so.6
(gdb) c
Continuing.
[Switching to Thread 16384 (LWP 12793)]
do_emit (ctx=0x10d38378, start=0, end=64, dest=0x34b6d020) at t_vertex.c:1028
in t_vertex.c
(gdb) bt
#0 do_emit (ctx=0x10d38378, start=0, end=64, dest=0x34b6d020) at t_vertex.c:1028
#1 0x0f6b5bec in do_emit (ctx=0x10d38378, start=0, end=64, dest=0x34b6d020) at t_vertex.c:1018
#2 0x0f697b9c in _tnl_run_pipeline (ctx=0x34b6d020) at t_pipeline.c:159
#3 0x0f6e7b18 in r200WrapRunPipeline (ctx=0x10d38378) at r200_state.c:2270
#4 0x0f6bd2d4 in _tnl_flush_vtx (ctx=0x10d38378) at t_vtx_exec.c:282
#5 0x0f6bba94 in _tnl_End () at t_vtx_api.c:790
#6 0x0fc525ac in glEnd () from /usr/X11R6/lib/libGL.so.1
#7 0x1053da58 in meshDM_drawFacesTex (dm=0x10f45084, setDrawParams=0x1014ff18 <draw_tface_mesh__set_draw>)
at DerivedMesh.c:420
#8 0x1015052c in draw_tface_mesh (ob=0x1119d6dc, me=0x111aa36c, dt=4) at drawmesh.c:904
#9 0x10352f30 in draw_mesh_fancy (ob=0x1119d6dc, baseDM=0x10f44fec, dm=0x10f45084, dt=4) at drawobject.c:1669
#10 0x10353684 in draw_mesh_object (base=0x11116a9c, dt=4) at drawobject.c:1793
#11 0x1035977c in draw_object (base=0x11116a9c) at drawobject.c:3426
#12 0x102d3974 in view3d_opengl_select (buffer=0x7ffc1850, bufsize=10000, x1=498, y1=319, x2=526, y2=347)
at view.c:1019
#13 0x101dd89c in mixed_bones_object_selectbuffer (buffer=0x7ffc1850, mval=0x7ffcb4a0) at editview.c:1102
#14 0x101ddfd8 in mouse_select () at editview.c:1191
#15 0x10290418 in winqreadview3dspace (sa=0x0, spacedata=0x11116a9c, evt=0x0) at space.c:951
#16 0x102a1b2c in scrarea_do_winhandle (area=0x11107e1c, evt=0x7ffcb570) at spacetypes.c:144
#17 0x101c4f60 in scrarea_dispatch_events (sa=0x11107e1c) at editscreen.c:563
#18 0x101c6f90 in screen_dispatch_events () at editscreen.c:1122
#19 0x101c7ab0 in screenmain () at editscreen.c:1366
#20 0x1014da68 in main (argc=2, argv=0x7ffcb6c4) at creator.c:584
Inloggad: JA
user_id=3093
A dist-upgrade to ubuntu breezy solved the problem. :-)
anders@jupiter:~$ glxinfo
GLX version: 1.2
GLX extensions:
OpenGL renderer string: Mesa DRI R200 20041207 AGP 1x TCL
OpenGL version string: 1.3 Mesa 6.3.2
OpenGL extensions:
GL_EXT_copy_texture, GL_EXT_draw_range_elements, GL_EXT_fog_coord,
GL_EXT_histogram, GL_EXT_packed_pixels, GL_EXT_polygon_offset,
GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_stencil_wrap, GL_EXT_subtexture,
GL_EXT_texture, GL_EXT_texture3D, GL_EXT_texture_edge_clamp,
GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_vertex_array,
GL_APPLE_packed_pixels, GL_ATI_blend_equation_separate,
GL_ATI_texture_env_combine3, GL_ATI_texture_mirror_once,
GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat,
GL_INGR_blend_func_separate, GL_MESA_pack_invert, GL_MESA_ycbcr_texture,
GL_MESA_window_pos, GL_NV_blend_square, GL_NV_light_max_exponent,
GL_NV_texture_rectangle, GL_NV_texgen_reflection, GL_OES_read_format,
GL_SGI_color_matrix, GL_SGI_color_table, GL_SGIS_generate_mipmap,
GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp,
GL_SGIS_texture_lod
glu version: 1.3
glu extensions:
Logged In: YES
user_id=103
Thanks for the notice.
One would expect by now that bigger linux distros have blender in their regression suite to check before releasing. :) Maybe this is something the users of distros have to be more active in, communicating it back to Ubuntu for example. Blender isn't easily to test automatic though, especially not for the GUI side.
Logged In: YES
user_id=2923
please confirm that this is still a problem with current CVS builds any unconfirmed bugs by the end of the week will be closed (they can be reoppened though).
you can get a current cvs build from
http://blender.org/forum/viewforum.php?f=18
