"Rotate around selection" does not affect 3Dmouse
Closed, ArchivedPublicTO DO
Reproduce
Open preferences -> Interface
Check "Rotate around Selection"
navigate with 3D-mouse
Win 7 64bit
Blender 2.59 64bit
SpaceExplorer driver 3.14.1 (64bit)
Assigning to Mike for investigation.
Nathan: I guess the "3d mouse" is the 3DConnexion device... this is just a missing feature, for the todo?
For todo definitely. Need to check ndof center of interest vs rotate around selection (one can pan around the first, essentially overriding rotate around selection).
Ideally changing selection should reset ndof center of interest to what rotate around selection gives.
Added on todo:
http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/UserInterface#Issues_per_category
Mike, if you re-open issue it needed to be somehow handled. Can't see activity here for a couple of months and it doesn't look like a real bug, just non-implemented feature. Such things easier to be tracked at wiki page.
Sergey Sharybin (sergey) changed the task status from Unknown Status to Unknown Status.Apr 3 2012, 3:43 PM
