The Interface Editor Window buttons (and sometimes icons) are drawn incrementally larger than before upon redraws. A new Interface Editor Window has the buttons and icons very tiny. The increase in size is occurs noticeably after making a render of image and go "Back to Previous" when the interface is redrawn, or after re-sizing the editor window (hiding another interface window).
Attached is an image with an older Editor Window now having large buttons, and a newly made Editor Window that has the tiny buttons.
Here is the system-info.txt:
= Blender 2.59 (sub 0) System Information =
Blender:
version 2.59 (sub 0), revision 39307. Release
build date: 2011-08-13, 11:44:03
platform: Windows:64bit
binary path: C:\Program Files\Blender Foundation\Blender\blender.exe
build cflags: /nologo /Ob1 /J /W0 /Gd /wd4018 /wd4244 /wd4305 /wd4800 /wd4065 /wd4267 /we4013 /openmp -DWITH_AUDASPACE -O2 -DNDEBUG -O2 -DNDEBUG -DWIN32 -D_CONSOLE -D_LIB -D_CRT_SECURE_NO_DEPRECATE /openmp -DWITH_AUDASPACE
build cxxflags: /nologo /Ob1 /J /W0 /Gd /wd4018 /wd4244 /wd4305 /wd4800 /wd4065 /wd4267 /we4013 /openmp -DWITH_AUDASPACE /EHsc /openmp -DWITH_AUDASPACE -O2 -DNDEBUG -O2 -DNDEBUG -DWIN32 -D_CONSOLE -D_LIB -D_CRT_SECURE_NO_DEPRECATE /openmp -DWITH_AUDASPACE
build linkflags: /SUBSYSTEM:CONSOLE /MACHINE:IX86 /STACK:2097152 /INCREMENTAL:NO /LARGEADDRESSAWARE /NODEFAULTLIB:msvcrt.lib /NODEFAULTLIB:msvcmrt.lib /NODEFAULTLIB:msvcurt.lib /NODEFAULTLIB:msvcrtd.lib
build system: SCons
Python:
version: 3.2 (r32:88445, Mar 4 2011, 02:13:51) [MSC v.1500 32 bit (Intel)]
paths:
C:\Program Files\Blender Foundation\Blender\2.59\scripts\addons
C:\Program Files\Blender Foundation\Blender\2.59\scripts\startup
C:\Program Files\Blender Foundation\Blender\2.59\scripts\modules
C:\Program Files\Blender Foundation\Blender\2.59\python
C:\Program Files\Blender Foundation\Blender\python32.zip
C:\Program Files\Blender Foundation\Blender\2.59\python\DLLs
C:\Program Files\Blender Foundation\Blender\2.59\python\lib
C:\Program Files\Blender Foundation\Blender\2.59\scripts\addons\modules
Directories:
scripts: ['C:\\Program Files\\Blender Foundation\\Blender\\2.59\\scripts']
user scripts: None
datafiles: C:\Documents and Settings\SAINT 13\Application Data\Blender Foundation\Blender\2.59\datafiles\
config: C:\Documents and Settings\SAINT 13\Application Data\Blender Foundation\Blender\2.59\config\
scripts : C:\Documents and Settings\SAINT 13\Application Data\Blender Foundation\Blender\2.59\scripts\
autosave: C:\Documents and Settings\SAINT 13\Application Data\Blender Foundation\Blender\2.59\autosave\
tempdir: C:\DOCUME~1\SAINT1~1\LOCALS~1\Temp\
renderer: ATI Mobility Radeon X2300 x86/SSE2
vendor: ATI Technologies Inc.
version: 2.0.6471 WinXP Release
extensions:
GL_ARB_multitexture GL_EXT_texture_env_add
GL_EXT_compiled_vertex_array GL_S3_s3tc GL_ARB_depth_texture
GL_ARB_fragment_program GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader GL_ARB_multisample GL_ARB_occlusion_query
GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shader_objects
GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_shadow_ambient
GL_ARB_texture_border_clamp GL_ARB_texture_compression
GL_ARB_texture_cube_map GL_ARB_texture_env_add
GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3 GL_ARB_texture_float
GL_ARB_texture_mirrored_repeat GL_ARB_texture_rectangle
GL_ARB_transpose_matrix GL_ARB_vertex_blend
GL_ARB_vertex_buffer_object GL_ARB_pixel_buffer_object
GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos
GL_ARB_draw_buffers GL_ATI_draw_buffers GL_ATI_element_array
GL_ATI_envmap_bumpmap GL_ATI_fragment_shader GL_ATI_map_object_buffer
GL_ATI_separate_stencil GL_ATI_shader_texture_lod
GL_ATI_texture_compression_3dc GL_ATI_texture_env_combine3
GL_ATI_texture_float GL_ATI_texture_mirror_once
GL_ATI_vertex_array_object GL_ATI_vertex_attrib_array_object
GL_ATI_vertex_streams GL_ATIX_texture_env_combine3
GL_ATIX_texture_env_route GL_ATIX_vertex_shader_output_point_size
GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate
GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint
GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_object
GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_point_parameters
GL_EXT_rescale_normal GL_EXT_secondary_color
GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_wrap
GL_EXT_texgen_reflection GL_EXT_texture3D
GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map
GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine
GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic
GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp
GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_vertex_array
GL_EXT_vertex_shader GL_HP_occlusion_test GL_NV_blend_square
GL_NV_occlusion_query GL_NV_texgen_reflection GL_SGI_color_matrix
GL_SGIS_generate_mipmap GL_SGIS_multitexture
GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp
GL_SGIS_texture_lod GL_SUN_multi_draw_arrays GL_WIN_swap_hint
WGL_EXT_extensions_string WGL_EXT_swap_control
Comment Actions
Hi,
I realize it's annoying, but you are using the still unsupported "horizontal layout" for buttons. Only vertical layouts work as expected now.
The issue is an active item on our todo in wiki.
