Failure to save LAST new Input item completely in User Preferences / Input tab
BLENDER BUG: 2.59
In user preferences, "Input" tab / 3D View / Mesh, I am adding three "Context Set Values"
I can test them, save them, and they work fine until I close the program and re-open.
I then find that the last of the three is missing some of it's info, as if it was not saved, especially it's "value" (False,False,True).
After many tests with the same results, I found that if I added an extra "Context Set Values" and simply copied the info from the one above, then it would be the one which failed to save. It became a "dummy" item, so to speak, and the three above it would then work after closing and re-opening the program.
Summary: Whichever new Input item is added last fails to save completely when the program is closed and re-opened, even though it was properly saved using both the "Save As Default" button and the Ctrl U save.
This same problem occurs on both my 32bit Vista and my 64bit Vista. The fix works on both.
The attached JPG shows the "dummy" as #4 (which was a duplicate of #3). It is missing info after closing and reopening Blender 2.59.
Brecht, you know this code better. Can you look at this problem?
Duplicate of this report:
http://projects.blender.org/tracker/index.php?func=detail&aid=28202&group_id=9&atid=498
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Archived.Sep 8 2011, 3:06 PM
