I am getting a crash while launching Blender 2.5.9 (either 32 or 64 bit) on OSX Lion
The previous release, 2.5.8 works fine.
To reproduce: just launch the app after unzipping, it will crash right after launching.
Not sure why it is crashing, but it mention 3dconnexion; and this is my 3d navigator device that I use with my Wacom tablet; are the 3dconnexion drivers not working with the new build of Blender?
Regression from 2.5.8
OS: Lion 10.7.1
Mac Pro 1.1 2x2.66 GHz quad core Intel Xeon
7 Gb DDR2 667MHz
ATI Radeon 3870 512Mb
This is the crash log:
Process: blender [6314]
Path: /Users/USER/Downloads/*/blender.app/Contents/MacOS/blender
Identifier: org.blenderfoundation.blender
Version: 2.59 (2.59, 2011-Aug-11, Blender Foundation)
Code Type: X86 (Native)
Parent Process: launchd [217]
Date/Time: 2011-09-02 01:21:06.769 -0700
OS Version: Mac OS X 10.7.1 (11B26)
Report Version: 9
Interval Since Last Report: 815193 sec
Crashes Since Last Report: 2
Per-App Interval Since Last Report: 6 sec
Per-App Crashes Since Last Report: 5
Anonymous UUID: C0ADCAA8-8C52-483F-9BFC-8015B2472A56
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
objc[6314]: garbage collection is OFF
Dyld Error Message:
Symbol not found: _SetConnexionClientButtonMask
Referenced from: /Users/USER/Downloads/*/blender.app/Contents/MacOS/blender
Expected in: /Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 dyld 0x8fe87071 dyld_fatal_error + 1
1 dyld 0x8fe8ac5f dyld::fastBindLazySymbol(ImageLoader**, unsigned long) + 140
2 libdyld.dylib 0x9602b84c dyld_stub_binder_ + 20
3 org.blenderfoundation.blender 0x00a0acf3 GHOST_NDOFManagerCocoa::GHOST_NDOFManagerCocoa(GHOST_System&) + 227
4 org.blenderfoundation.blender 0x00a0e76d GHOST_SystemCocoa::init() + 93
5 org.blenderfoundation.blender 0x00a072f8 GHOST_ISystem::createSystem() + 88
6 org.blenderfoundation.blender 0x00a0487b GHOST_CreateSystem + 11
7 org.blenderfoundation.blender 0x0016572c wm_ghost_init + 76
8 org.blenderfoundation.blender 0x001577b8 WM_init + 424
9 org.blenderfoundation.blender 0x0014c4e5 main + 620
10 org.blenderfoundation.blender 0x001498aa start + 54
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x9705a90a kevent + 10
1 libdispatch.dylib 0x9a7c1ccc _dispatch_mgr_invoke + 969
2 libdispatch.dylib 0x9a7c071b _dispatch_mgr_thread + 53
Thread 2:
0 libsystem_kernel.dylib 0x9705a02e __workq_kernreturn + 10
1 libsystem_c.dylib 0x9a8e6ccf _pthread_wqthread + 773
2 libsystem_c.dylib 0x9a8e86fe start_wqthread + 30
Thread 3:
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x8fe921a6 ebx: 0x00a0ac24 ecx: 0x00000000 edx: 0x80808080
edi: 0x8feba190 esi: 0x8fe8ab82 ebp: 0xbffffa18 esp: 0xbffff9fc
ss: 0x0000001f efl: 0x00000202 eip: 0x8fe87071 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x8feb1910
Logical CPU: 2
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 3
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 19461
thread_create: 0
thread_set_state: 20
VM Region Summary:
ReadOnly portion of Libraries: Total=202.5M resident=105.2M(52%) swapped_out_or_unallocated=97.3M(48%)
Writable regions: Total=105.6M written=2380K(2%) resident=4308K(4%) swapped_out=4K(0%) unallocated=101.3M(96%)
REGION TYPE VIRTUAL
ATS (font support) 32.0M
ATS (font support) (reserved) 4K reserved VM address space (unallocated)
CG shared images 128K
CoreServices 2056K
MALLOC 38.2M
MALLOC guard page 32K
Memory tag=242 12K
Memory tag=249 156K
Stack 65.5M
VM_ALLOCATE 16.0M
__CI_BITMAP 80K
__DATA 22.8M
__DATA/__OBJC 68K
__IMAGE 1256K
__IMPORT 20K
__LINKEDIT 59.1M
__OBJC 1444K
__OBJC/__DATA 4K
__PAGEZERO 4K
__TEXT 143.4M
__UNICODE 544K
mapped file 109.3M
shared memory 312K
shared pmap 9176K
TOTAL 501.3M
TOTAL, minus reserved VM space 501.3M
Model: MacPro1,1, BootROM MP11.005C.B08, 8 processors, 2.66 GHz, 7 GB, SMC 1.7f10
Graphics: ATI Radeon HD 3870, ATI Radeon HD 3870, PCIe, 512 MB
Memory Module: DIMM Riser A/DIMM 1, 1 GB, DDR2 FB-DIMM, 667 MHz, 0x0416, 0x4E4C43313237413236343037462D4435334D
Memory Module: DIMM Riser A/DIMM 2, 1 GB, DDR2 FB-DIMM, 667 MHz, 0x0416, 0x4E4C43313237413236343037462D4435334D
Memory Module: DIMM Riser B/DIMM 1, 2 GB, DDR2 FB-DIMM, 667 MHz, 0x0000, 0x000000463732353642363145353636374600
Memory Module: DIMM Riser B/DIMM 2, 2 GB, DDR2 FB-DIMM, 667 MHz, 0x0000, 0x000000463732353642363145353636374600
Memory Module: DIMM Riser A/DIMM 3, 512 MB, DDR2 FB-DIMM, 667 MHz, 0x802C, 0x39485446363437324A592D36363742344433
Memory Module: DIMM Riser A/DIMM 4, 512 MB, DDR2 FB-DIMM, 667 MHz, 0x802C, 0x39485446363437324A592D36363742344433
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x87), Broadcom BCM43xx 1.0 (5.10.131.36.11)
Bluetooth: Version 2.5.0f17, 2 service, 12 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en2
PCI Card: ATI Radeon HD 3870, sppci_displaycontroller, Slot-1
PCI Card: ATI Radeon HD 3870, ATY,MegalodonParent, Slot-1
Serial ATA Device: ST3500320AS, 500.11 GB
Serial ATA Device: OCZ-VERTEX2 3.5, 90.03 GB
Serial ATA Device: MAXTOR STM31000340AS, 1 TB
Serial ATA Device: Hitachi HDT721010SLA360, 1 TB
Parallel ATA Device: PIONEER DVD-RW DVR-118L
Parallel ATA Device: OPTIARC DVD RW AD-7170A
USB Device: EyeTV Hybrid, 0x0fd9, 0x0024, 0xfd500000 / 3
USB Device: hub_device, 0x058f (Alcor Micro, Corp.), 0x6254, 0xfd400000 / 2
USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0xfd440000 / 4
USB Device: USB Optical Mouse, 0x046d (Logitech Inc.), 0xc05a, 0xfd443000 / 6
USB Device: Apple Keyboard, apple_vendor_id, 0x0220, 0xfd442000 / 5
USB Device: io|2, 0x13b2, 0x0008, 0x3d100000 / 2
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8206, 0x5d200000 / 2
FireWire Device: built-in_hub, 800mbit_speed
Comment Actions
Did you got the 2.59 very early ? We made a silent update for compat. with older NDOF drivers just a few days
after release. If so, try get Blender 2.59 again.
If not: try at least driver 1.6.3 or the new beta 10 drivers, these where tested o.k..
Jens
Comment Actions
I've got 2.5.9 yesterday
when you say 1.6.3 drivers, of which component are you talking about?
Comment Actions
This is about the 3Dconnexion SpaceNavigator drivers, did you have these installed, and if so which version?
