Port of Willian P Gerano's AC3D Import/Export (as found in 2.48) to 2.59
Closed, ArchivedPublicPATCH
Project: Blender Extensions
Tracker: Py Scripts Upload
Blender: 2.59
Category: Import Export
Python: 3.2
Homepage: https://github.com/majic79/Blender-AC3D
Script name: Blender-AC3D
Author(s): Willian P Gerano, Chris Marr
Status: Open
I wanted to play with blender, specifically with flightgear's .ac models, and I was fustrated by the lack of AC3D (.ac) file format support.
I ported the 2.48 import/Export script into a io_scene_ac3d addon script folder to tweak and make it work inside of 2.59
Known issues:
- Doesn't correctly bring in uv textures
- Export's not working (yet)
- faces with more than 3 vertices are still broken...
Hi william and chris....
I write a .ac import/export script ....
Please test this script, and if your script is better I close my project.
http://projects.blender.org/tracker/index.php?func=detail&aid=28369&group_id=153&atid=467
My script was tested with flightgear 3D developer, from "paf forum".
http://equipe-flightgear.forumactif.com/
Today my script run on windows and linux system. The script name is io_scene_ac
Hi,
Due to changes to the api including the merging of bmesh, several addons are outdated.
Please, if you are the author of an addon check your script with blender revision 44256 or newer.
That is builds made After blender 2.62 official release.
I would ask that updates be made to your addon before the Blender 2.63 release.
6-8 weeks away.
This allows time for the api to become more exposed & bmesh to stablize furthur.
If you need help, drop into irc freenode #blenderpython or #blendercoders & feel welcome to ask questions.
At the time of 2.63 release, scripts that are not repaired or in active developement will have their tracker page marked "Closed"
this will not affect your links to the tracker, similar to closing scripts in 2.49b, the page will be still availible & can be re-opened.
Thanks for your understanding & patience during these Exciting Times.
Brendon.
hi this addon needs updating for bmesh.
I won't close yet please update soon.
@ Rene , I closed your page, you are welcome to contribute to this addon also if you like.
Brendon Murphy (meta-androcto) changed the task status from Unknown Status to Unknown Status.Sep 1 2015, 11:42 AM
hi, this task is being archived.
Chris Marr (majic79).,
feel free to resubmit in a new task if your still working on this addon.
