Add-on to control 3D view with accelerometer data, received over network.
Closed, ArchivedPublicPATCH
Project: Blender Extensions
Tracker: Py Scripts Upload
Blender: 2.58
Category: 3D View
Python: 3.2
Script name: accelBlend
Author(s): Сергій Загорія
Status: Closed
Receives accelerometer data over the network from the sender part on the mobile phone and uses it to control 3D view rotation.
Right now there is a sender part only for Nokia N900 as a command-line preview, but that's temporary as QML GUI version is on the go.
I cannot find a way to create a Wiki page.
Done:
http://wiki.blender.org/index.php/Extensions:2.5/Py/Scripts/3D_interaction/accelBlend
Hi,
Due to changes to the api including the merging of bmesh, several addons are outdated.
Please, if you are the author of an addon check your script with blender revision 44256 or newer.
That is builds made After blender 2.62 official release.
I would ask that updates be made to your addon before the Blender 2.63 release.
6-8 weeks away.
This allows time for the api to become more exposed & bmesh to stablize furthur.
If you need help, drop into irc freenode #blenderpython or #blendercoders & feel welcome to ask questions.
At the time of 2.63 release, scripts that are not repaired or in active developement will have their tracker page marked "Closed"
this will not affect your links to the tracker, similar to closing scripts in 2.49b, the page will be still availible & can be re-opened.
Thanks for your understanding & patience during these Exciting Times.
Brendon.
hi,
Currently I'm still unsure of the working state of this addon.
I'm closing this page for now. as part of 2.63 cleanup.
If you want to update & resubmit your addon please let me know & this page can be reopened easily.
Also note the page is closed but you can still use as a tracker page, only the status is closed.
Your wiki page is good.
Thanks for your addon & interest in Blender.
Brendon.
Brendon Murphy (meta-androcto) changed the task status from Unknown Status to Unknown Status.Apr 16 2012, 3:22 PM
