improvements about addon management
Closed, ArchivedPublicPATCH
Project: Blender Extensions
Tracker: Py Scripts Upload
Blender: 2.59
Category: Development
Homepage: https://github.com/littleneo/Blender-addon-dependencies
Script name: Addon dependencies
Author(s): littleneo
Status: Open
ADDON DEPENDENCIES V0.7
. the addon messages and this documentation are written in a froggy english
flavour : any help to improve messages and docs in intl. english are welcome.
. reading this can be tedious I know, but since some builtin files are replaced
it's better if you know a bit about the way it work...
DOWNLOAD
last revion (v0.71)
the tool is also available in the
http://blenderpython.svn.sourceforge.net/
script collections
INTRODUCTION
this addon installs or registers nothing, does not import any module, and
has no features by itself : it applies safely a patch (more exactly it
safely replaces some files) in Blender that gives some more features to the
addon builtin mecanism.
FEATURES :
. the patch can be safely enabled and disabled
. several checks are performed to avoid chaotic situations
(see the TESTED CASES section)
. replaced files are saved in the addon folder, by revision
(in /user)
. original files are provided, grouped by revision. (/ori)
. if the replaced files were themselves modded and that
you want to use them back when addon dependencies is disabled,
please see the USAGE section.
. add a light dependency feature between addons :
. an addon can declare it needs another addon to be enabled to run.
. in the case the other addon is not started, it will be done right
before it (v0.7).
several parents can be declared, each with their versions.
. a 'parent' addon can't be disabled if it's currently used by one or
several other addons. an addon does not need any modification
to become a 'parent', only the 'child' needs a particular field
in bl_info
. the mod is fully compatible with normal addons.
. the 'childs' addons are fully compatible with the normal version.
. icons and new fields are displayed when an addon is either a 'child'
or a 'parent' addon.
. creation of a 'child' addon is quick : one new field in bl_info.
. improvements for multi-modules addon development :
. get rid of the "already registered as a subclass" message when
unregister() was faulty.
. disabling then enabling an addon will reload and reread every module
of the addon not only the __init__ file (similar to F8 but for only
one module, or like the 'add a bug to __init__/reload/correct/reload'
trick)
. support dynamically created class (e.g. generated through exec)
without complaining.
to sum up, child modules of a main __init__ module are removed from
sys.modules when the addon is unregistered : this permits to reload/
disable everything with less complications. this is safe.
. addons can optionnally be disobedients :
at register() and unregister steps() an addon could decide to stay
active. this can be useful for cases where an addon has not finished
its job: it did not save a file, a modal op. is still running, he is
still performing a loop, or maybe the user needs to achieve something
before, etc..
to achieve this, register() and unregister() can return a simple string
explaining why the addon desobeys. the message will be reported in the
ui and in the console.
. bugged addon enabled by default are not marked enabled any longer.
. misc. goodies :
ui report and icons are used along with console to provide info about
the cases above. messages are displayed in various cases.
. nerds friendly (see NERDS SWITCHES section)
A WORKING EXAMPLE OF ADDONS USING THIS PATCH
. I'm writting a script called 'image tools', about image manipulation in
the image editor. it uses nconvert to crop, contrast, blur etc.
this addon needs a modal to draw a selection box for cropping selection :
rather than to write another modal function, I reuse an addon to provide
the modal management, so I can only maintain one generic code.
this second addons is called 'script events'
image tools :
http://blenderpython.svn.sourceforge.net/viewvc/blenderpython/259/scripts/addons_extern/image_tools/?view=tar
script events :
http://blenderpython.svn.sourceforge.net/viewvc/blenderpython/259/scripts/addons_extern/script_events/?view=tar
once installed, and if addon dependencies has patched the blender files,
the two scripts will be aware or their relationship, that will be displayed
in the user preferences > addons tab. if one enable image tools, it will
enable script events if it's not, or if image tools is enabled by default
and script event is not, it will be started either.
the connection between the two is done by adding the following field in
the bl_info of the image tools __init__ file :
"dependencies": "Script Events (0,4)"
nothing else. for sure the two scripts will also work with the original
blender files.
PATCHABLE BLENDER VERSIONS, OSes :
. v0.6 can patch Blender 2.59 and 2.60rc (respectively r39307 and 40791)
. the addon has been tested on XP pro 32bits, and first tests have been
made on linux and mac BUT THIS NEEDS MORE VALIDATIONS FOR THESE TWO.
. the worst case scenario is not that bad, only backup the original files
in a safe location if you run linux or macos (see modded files below)
before to run. also the addon is shipped with the 2.60rc original files.
(from the blender.org release zip, windows 32bit)
. no support for older windows OSes. I mean no warranty.
. blender revision check can be overriden if you know what you do. e.g. if
you use a graphicall build and want to force the patch
v0.6 MODDED FILES LIST :
. Blender 2.59 revision 39307 :
/modules/addon_utils.py
/startup/bl_ui/space_userpref.py
. Blender 2.60rc revision 40791 :
/startup/bl_operators/wm.py
the provided features are the same for both releases.
INSTALLATION :
. unzip the addon folder in scripts/addons or addons_extern or _contrib
. if a previous version of addon dependencies lesser than 0.6 is installed,
remove the modded files and rename the original files as it should,
as if everything was normal.
. if you udgrade from 0.6 or greater, simply replace the addon_dependencies
folder with the new one.
. unzip the addon in the blender scripts/addons directory,
. start Blender, open the console if you want to see logs,
. browse to Development in the user preferences / addon tab,
. (or search for 'addon')
. enable Addon Dependencies : patch is applied,
. restart Blender (mandatory) : patch is now running.
the addon can be enabled by default or not.
USAGE :
. applying patch / restoring files :
enable the addon to apply the patch,
disable the addon to restore.
if you disable it and it's enabled by default,
'save as default again' after disabling it, else it will be reapplied
at next run.
(see the other section for more technical info.)
. configure an addon as a 'child' addon :
in the bl_info of your addon add a new field called "dependencies"
then add the addon names or the addon module name and the version
using the following format :
"dependencies" : 'Script Events (0,1)'
if you need several parents, nest them in a list :
"dependencies" : [ 'Script Events (0,1)', 'RotoBezier (0.8)' ]
the previous syntax is still ok.
in case of wrong syntax, the child addon can't be enabled. an error
message is displayed describing the error in the user preference /
addon field.
. create a 'disobedient' addon :
it can be done at the register() and/or at the unregister() steps.
supposing you performed some tests to see if i's ok to enable or to
disable your addon, and supposing the tests return it's a no go, you
only need to return something like :
return False
or :
return "I'm not done yet, sorry, please do.."
NERDS SWITCHES
there's two variables in the __init__ file you can change for special use :
(top of the file)
. you want to force the patch to be applied in your build.
I won't provide patch for builds from graphicall. but if you think this
will work anyway, you can force a patch to be applied by setting :
fake_revision = < revision_number as string >
to the patch revision number you want to apply. a folder named as the
revision number must exist in /mod and a key name in the modded dict
must match too.
when you disable them the file of your build will be restored (and not
those shipped from the trunk)
a message is displayed in the console when you use this.
default is fake_revision = False.
. you already hacked files from the Blender distro, and you don't want to
loose them.
the 'not so original' files are saved in the addon /user folder.
as long as a file exists in the /user file, they are not updated again.
to restore them set :
use_user_files = True
the console tell which files are restored. in case of missing files in
/user, the trunk files from /ori are restored.
default is False
v0.6 RELEASE NOTES :
. work with no warranty on obsolete windows os because I unified the path
separators the unix way whatever the os is. which is the right and only way
paths should be written anyway.
you'll find below the complete set of done tests achieved on blender 2.58a,
2.59 and 2.60rc (respectively r38019, r39307 and 40791)
several checks are performed that must prevent any issues in case of
wrong usage.
. you can obtain more logs in the console to track register() unregister()
activities by setting verbose = True in the __init__ file of the addon.
TESTED CASES
tested cases were the following :
. enabling the v0.6 addon on blender 2.58a r38019 :
console must say :
Addon dependencies :
version mismatch :
this addon is compatible with blender revisions 39307, 40791,
but you currently use blender build (2, 58, 1) revision 38019.
the patch won't be applied.
patch is only applied if the right revision folder is found in the
addon release /mod folder AND if the __init__ file contains the
list of files to patch for each of these revisions
for the v0.6 addon, blender 2.59 and blender 2.60rc are the only
revisions that can be patched (r39307 and 40791).
with 2.58a there's an error logged in the console but I think I'm
not responsible about that..? ( 2.58a check addon version code in
userpref )
. enabling the addon in 2.59 and 2.60rc (r39307 and 40791) :
the first time, the files that will be patched are copied into :
addon_dependencies\user\<revision>
the first time the addon is enabled, console must say :
blender r<revision>, patch v.0.6
currently using the original files
saved current file in user/<revision>/<file_x>
saved current file in user/<revision>/<file_y>
copying mod/<revision>/<file_x>
copying mod/<revision>/<file_y>
patch installed, please restart Blender.
and the next times :
this has been done for the case the user is a blender files hacker
itself, so he can retrieve his own mods.
* if the user want to backup his files again, he first needs to remove
the corresponding files in addon_dependencies\user\<revision>
. disabling the addon :
console must say :
currently using the modded files
copying ori/<revision>/<file_x>
copying ori/<revision>/<file_y>
patch removed, please restart Blender.
the original files are shipped with the addon, they are located in :
addon_dependencies\ori\<revision>
the original files were copied from the zipped 32 bits windows package.
* if the user want to restore his own hack, he needs to manually copy
his files from the addon_dependencies\user\<revision> folder to the
right blender folders.
* in case of unpredicted chaos, the original files can be restored by
hand from addon_dependencies\ori\<revision> (shipped original files)
or from addon_dependencies\user\<revision> (backuped original files)
the corresponding paths are written in the __init__ file, in the
corresponding modded[revision] list
* if the addon is enabled by default and that you disable it, you need
to 'save as default', else when restarted, the addon will reinstall the
patch.
. files are patched and addon dependencies is disabled by default :
in this case, the addon is disabled in the user preference ui.
when 'enabling' it, console must say :
blender r40791, patch v.0.6
as the modded files are already there, it does nothing. and now the
addon is marked as enabled, so it's ok.
. addon dependencies is enabled by default (so files are patched) :
console :
it does not copy anything.
. evil user / ghost in the shell mixed modded and original files together :
(or mixed different revisions)
. addon dependencies is enabled by default (files are patched) :
ex copied an old modded addon_utils.py in the r40791 modded build :
addon_utils.py modded version does not match
copying mod/40791/addon_utils.py
copying mod/40791/wm.py
copying mod/40791/space_userpref.py
ex2 replaced the modded wm.py by the original in the modded build :
original and modded files are mixed !
if the addon is enabled by default and if the used files are not
the modded files, with the right blender revision, and the right
addon version, it applies the patch again, entirely.
. addon dependencies is disabled :
I can't help here.
but if the addon is enabled it will fix it by patching again, as
above.
. nerd user used the fake_revision and/or use_user_files switches
looks ok so far, tested with 2.59.0 and 4, enabling/disabling
TO DO LIST :
. check only for the presence of a parent module, or a particular
submodule within it, whatever it's enabled or not.
. pep80-80
TECHNICALLY :
. core modifications are made in addon_utils.py.
the other files are modified to handle returned messages and to report
in the ui or displays icons.
. every modded file include a 'tag line' at line 20, used for file (modded
or original) and versions (blender and addon) recognitions. I'd rather like
to make a CRC test but this is not bundled in python (afaik?)
lnmod = (39307,(0, 6)) # the line 20 tag
39307 is the blender revision whith which this file is compatible
(0, 6) is the version of the addon and the modded files
. modded files are rewritten for every published official version of Blender
to use these files with a non supported revision is not recommended, but
this is not so risky, provided you have some skills in python and a good
"compare file" tool. steps would be :
. compare mod/<revision>/file_x.py with ori/<revision>/file_x.py
. compare ori/<revision>/file_x.py with the file you want to mod
. carefully move code from mod to your file, and adapt to the new
code.
. addon_utils.py includes two new functions :
. dependencies() at the bottom. this is called by enable() at step 2
if the 'dependencies' field exists in the bl_info dict. this is
were the 'parent enabled' and 'parent version ok' tests occur.
. del_modules(module_name). this one replaces any
del sys.modules[module_name] call. the difference is that it will
also remove the 'childs' module of module_name, that will allow to
import everything again, and not only 'reload' them.
. bl_info (...)
HISTORY
v0.71
. improved reset_all() function. solves a case when two addons enabled by
default are located in two different folders e.g. the child in
addons_contrib and the parent in addons_extern.
the child was not able to enable its parent since the path was not
already known.
v0.7
bugs corrected :
.a bug occured when childs and parent addons were enabled by default and
that the parent addon was lodad before the child(s), that seriously damaged
the ui.
. when disabling, the ui was reporting warnings even if everything was ok.
improved :
. parent addon are enabled if they were not, at the moment they are needed:
enabling an addon will enable its parent if any.
. enabled by default parent addon now list their childs addons.
. bugged modules are not marked enabled any longer.
Nice and useful. I'll use the dependency field in my next addon.
"I'd rather like to make a CRC test but this is not bundled in python (afaik?)"
See module 'hashlib', and 'zlib' specifically for crc32.
thanks for the pointers daniel !
it looks like it work fine. it would be very helpful if someone can run this little test here on other OSses than mine :
https://github.com/littleneo/Blender-addon-dependencies/blob/master/crc_test.zip?raw=true
it performs a quick file test and generates a text block with results in it one can paste
at http://www.pasteall.org/ to my intention.
crc should be the same whatever the os 32/64 but it's better to check before to push.
Hi,
Due to changes to the api including the merging of bmesh, several addons are outdated.
Please, if you are the author of an addon check your script with blender revision 44256 or newer.
That is builds made After blender 2.62 official release.
I would ask that updates be made to your addon before the Blender 2.63 release.
6-8 weeks away.
This allows time for the api to become more exposed & bmesh to stablize furthur.
If you need help, drop into irc freenode #blenderpython or #blendercoders & feel welcome to ask questions.
At the time of 2.63 release, scripts that are not repaired or in active developement will have their tracker page marked "Closed"
this will not affect your links to the tracker, similar to closing scripts in 2.49b, the page will be still availible & can be re-opened.
Thanks for your understanding & patience during these Exciting Times.
Brendon.
Brendon Murphy (meta-androcto) changed the task status from Unknown Status to Unknown Status.Sep 1 2015, 3:03 PM
Closing as archived, task over 3 years old.
Jerome Mahieux (littleneo)
feel free to resubmit a new task if this addon is still being worked on.
