i append some objects from 2 files from 2.49 and
when i tried to select anything like text object then it crashes and i cannot save thsi file undere antoher name cause it will have the same bug
open the file and try to select and move things around and it crashes
vista 32 bits version 41377
thanks
here is the last file i used and append from this file 3 objects like plane torus and cube i think
then i copied one of the txt in the 2.6 file and change the text content .
the next time i opened it up and try to select in the right corner near the oranges objects it crashe
if you need the first file i can upload too but did not have any problem with that one!
but let me know
thanks
It's still not really clear for me how to reproduce crash. I've tried to open attached to report file,select different objects and move them -- no crash at all.
well i tried again with 41377 this morning and i can open it up but as soon as i click to select an object it crashes
it looks like i cannot add a new pic here in post!
but i could open a thread on blenderartist to show the viewport before i click when i first iopen it up!
hope youc an reproduce it
i could make short video but don't know if i can uplaod it here
let me know!
thanks
did some other test this morning
i tried with 40789 and it crashes too
but i did a test with cycle 41206 and it works fine !
dont' understand why it is crashing on some version and not with 206 !
very strange problem
i'll try to get lastest version today or tomorrow and see if it crashes too!
thanks
don't know what to say about this bug !
i ask on a thread to test another file i uploaded
and no one else seems to have a problem which is very strange!
Tested on 64 vits XP and even one vista 32 bits!
http://blenderartists.org/forum/showthread.php?235446-test-on-crashing-file-or-not
i can open theses files with Cycle 41206 and no problems
but with other version i crashes!
i tried this morning SVN 41484 and i can open it but it crashes immediately !
dont's understand why on vista 32 bits the only SVN working fine is Cycle 41206!
so close it down and i'll re open a new bug report later on next month if problem is still there!
happy 2.6
Tried to redo this bug in r41602 on linux, 64bit and no crash, also valgrind reported no issues.
- appended all objects from Wood_orange_material.blend
- select each of them in wire and solid mode
- save, reload and try again...
Everything goes fine.
If it crashes when you're clicking on object to select -- most probably it's video driver issue. There were some changes made in this area so probably you'll want to test fresh builds from http://builder.blender.org/download/
Sad thing about such kind of problems that we can't fix them until somebody from developers will reproduce it. Moving report to OpenGL tracker because it's most probably where issue lies. Feel free to add additional information here and we'll check it.
well ttoday on the thread i open one other guy was able to crash with thid file !
see
http://blenderartists.org/forum/showthread.php?235446-test-on-crashing-file-or-not&p=1985462#post1985462
""" quote
I tried your .blend file in with Blender 2.60a running XP on a laptop and DOWN SHE WENT when I tried to select one of your objects.
It's a Celeron M @ 1.50 Ghz with 504MB of RAM, if that helps.
happy 2.6
ok today got same crashing problem by selecting in a file where i imported objects from another cycle file
SVN 41759 cycle vista 32 bits
but this time it is only between files in 2.6 (append)
i include the bugging files and tried to select some of the objects at front and it crashes everytime!
hope this time you can reproduce it with this new file
could not load file here
so here is the new file at post 11 in this thread
http://blenderartists.org/forum/showthread.php?235446-test-on-crashing-file-or-not&p=1987062#post1987062
thanks guys
