Return of the screen colors
r41899 compiled here in Ubuntu 11.10
Dell Latitude D510, Pentium M, 2GB RAM
Intel 915 graphics
The odd colors in the right hand side of the Blender screen have returned. Please see attached pics.
The colors come fairly often, but not always, when right-clicking, especially in the right-hand side of the display, Also when left-clicking to select drop-down items in the right side of the screen. Happens with both the default Cycles scene and another simple scene, both in Cycles render mode and Blender Internal setting, but not in Game Engine setting.
Memory use is 25%, of which Blender takes only 36MB.
Doesn't happen in main release r41098.
Again, here is the output from System Info:
= Blender 2.60 (sub 4) System Information =
Blender:
version 2.60 (sub 4), revision 41899. Release
build date: 2011-11-16, 07:42:43
platform: Linux
binary path: /home/tm/build/bin/blender
build cflags: -fopenmp -msse2 -msse -pipe -fPIC -funsigned-char -fno-strict-aliasing -Wall -Wcast-align -Werror=declaration-after-statement -Werror=implicit-function-declaration -Werror=return-type -Wstrict-prototypes -Wno-char-subscripts -Wno-unknown-pragmas -Wpointer-arith -Wunused-parameter -Wwrite-strings -Wno-error=unused-but-set-variable
build cxxflags: -fopenmp -msse2 -msse -pipe -fPIC -funsigned-char -fno-strict-aliasing -Wall -Wno-invalid-offsetof -Wno-sign-compare
build linkflags: -pthread
build system: CMake
Python:
version: 3.2.2 (default, Sep 5 2011, 22:21:39)
[GCC 4.6.1]
paths:
/home/tm/build/bin/2.60/scripts/addons
/home/tm/build/bin/2.60/scripts/startup
/home/tm/build/bin/2.60/scripts/modules
/home/tm/build/bin/2.60/python/lib/python3.2/
/home/tm/build/bin/2.60/python/lib/python3.2/plat-linux2
/home/tm/build/bin/2.60/python/lib/python3.2/lib-dynload
/home/tm/build/bin/2.60/scripts/addons/modules
Directories:
scripts: ['/home/tm/build/bin/2.60/scripts']
user scripts: None
datafiles: /home/tm/.blender/2.60/datafiles/
config: /home/tm/.blender/2.60/config/
scripts : /home/tm/.blender/2.60/scripts/
autosave: /home/tm/.blender/2.60/autosave/
tempdir: /tmp/
renderer: Mesa DRI Intel(R) 915GM x86/MMX/SSE2
vendor: Tungsten Graphics, Inc
version: 1.4 Mesa 7.11
extensions:
GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color
GL_EXT_blend_logic_op GL_EXT_blend_minmax GL_EXT_blend_subtract
GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture
GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array
GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip
GL_ARB_point_parameters GL_EXT_draw_range_elements
GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal
GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp
GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp
GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_multitexture
GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat
GL_3DFX_texture_compression_FXT1 GL_ARB_texture_cube_map
GL_ARB_texture_env_add GL_ARB_transpose_matrix
GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays
GL_EXT_secondary_color GL_EXT_texture_env_add
GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias
GL_INGR_blend_func_separate GL_NV_blend_square
GL_NV_light_max_exponent GL_NV_texgen_reflection
GL_NV_texture_env_combine4 GL_SUN_multi_draw_arrays
GL_ARB_texture_border_clamp GL_ARB_texture_compression
GL_EXT_framebuffer_object GL_EXT_texture_env_dot3 GL_MESA_window_pos
GL_NV_packed_depth_stencil GL_NV_texture_rectangle
GL_NV_vertex_program GL_ARB_depth_texture GL_ARB_shadow
GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat
GL_ARB_window_pos GL_EXT_stencil_two_side GL_EXT_texture_cube_map
GL_NV_vertex_program1_1 GL_APPLE_client_storage GL_APPLE_packed_pixels
GL_APPLE_vertex_array_object GL_ARB_draw_buffers
GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects
GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers
GL_ATI_texture_env_combine3 GL_EXT_shadow_funcs GL_EXT_stencil_wrap
GL_MESA_pack_invert GL_MESA_ycbcr_texture GL_ARB_half_float_pixel
GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync
GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object
GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate
GL_OES_read_format GL_ARB_pixel_buffer_object GL_ARB_texture_rectangle
GL_EXT_pixel_buffer_object GL_EXT_texture_rectangle
GL_ARB_framebuffer_object GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil
GL_APPLE_object_purgeable GL_ARB_vertex_array_object
GL_ATI_separate_stencil GL_EXT_gpu_program_parameters
GL_EXT_texture_env_combine GL_OES_EGL_image GL_ARB_copy_buffer
GL_ARB_map_buffer_range GL_EXT_separate_shader_objects
GL_ARB_ES2_compatibility GL_ARB_draw_elements_base_vertex
GL_ARB_explicit_attrib_location GL_ARB_provoking_vertex
GL_ARB_sampler_objects GL_EXT_provoking_vertex GL_ARB_robustness
Most probably it's crappy intel drivers. What you my want to check, is to copy lib/ forlder and blender-softwaregl script from release archive to the same folder where recent blender binary is located and try running blender-softwaregl. And please try this with builds from out buildbot site (http://builder.blender.org/download/).
Sergey Sharybin (sergey) changed the task status from Unknown Status to Unknown Status.Nov 21 2011, 1:12 PM
Checked with valgrind and bugle and didn't find any issues with opengl usage from our side. Will move to OpenGL tracker. Feel free to provide additional info here and we'll make everything we can do to fix this issue.
Moved from Blender 2.5 Bug Tracker to OpenGL errors
Hi Sergey,
I copied the file and folder into build/bin folder of my latest Blender build and ran the script. The result was that all graphics on my monitor froze in a washed out state and the following errors were reported in the terminal:
Connect failed
ndof: spacenavd not found
found bundled python
warning - no scene
I had to reboot to exit this state.
I'm now downloading http://builder.blender.org/download/blender-2.60-r42152-linux-glibc27-i686.tar.bz2 on a slow Inet connection and will let you know the result of applying the same procedure to that build shortly.
Running r42152 from BuildBot with blender-softwaregl gives a similar result to running with r41899 compiled on my system - the Blender window turns pale translucent yellow and the system hangs. Same result when running release 41098. My system doesn't like the blender-softwaregl script.
