Segfault / hang on shutdown when rendering from script (NVidia driver bug?)
I was toying around with rendering a set of frames from a Python script:
t_shutdown.py
import bpy
scene = bpy.context.scene
render = scene.render
render.resolution_x = 960
render.resolution_y = 540
render.resolution_percentage = 100
render.image_settings.file_format = 'PNG'
for frame in [1, 4, 6]:
scene.frame_current = frame
render.filepath = '/tmp/doh%04d.png' % frame
bpy.ops.render.render(write_still=True, animation=False)
When I run this script with blender -b -P ./t_shutdown.py the rendering
sometimes hangs at exit, sometimes segfaults at exit and sometimes succeeds.
I tried to get some stacktraces, seems to be something to do with shutdown
and unloading NVidia libraries:
Hang (stack trace from gdb -p <pid>):
(gdb) bt
#0 0x00007f44f1754c21 in _nv012tls ()
from /usr/lib/tls/libnvidia-tls.so.285.05.09
#1 0x00007f44f72bce33 in ?? () from /usr/lib/libGL.so.1
#2 0x00007f44f729c379 in ?? () from /usr/lib/libGL.so.1
#3 0x00007f44f753c3ec in _dl_fini () at dl-fini.c:248
#4 0x00007f44f2038262 in __run_exit_handlers (status=0) at exit.c:78
#5 *__GI_exit (status=0) at exit.c:100
#6 0x00000000007f9478 in WM_exit (C=<value optimized out>)
at /home/paulmlocal/c/blender-svn/source/blender/windowmanager/intern/wm_init_exit.c:463
#7 0x00000000007eefb8 in main (argc=4, argv=0x7fffef4d41f8)
at /home/paulmlocal/c/blender-svn/source/creator/creator.c:1247
Crash:
(gdb) bt
#0 0x00007f0011181a08 in _nv007tls () from /usr/lib/tls/libnvidia-tls.so.285.05.09
#1 0x00007f0015c9ea61 in __nptl_deallocate_tsd (arg=<value optimized out>) at pthread_create.c:155
#2 start_thread (arg=<value optimized out>) at pthread_create.c:307
#3 0x00007f0011b1270d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:112
#4 0x0000000000000000 in ?? ()
Blender info:
Blender 2.60 (sub 5)
build date: 2011-11-24
build time: 13:16:12
build revision: 42122
build platform: Linux
build type: RelWithDebInfo
build c flags: -fopenmp -msse2 -msse -pipe -fPIC -funsigned-char -fno-strict-aliasing -Wall -Wcast-align -Werror=declaration-after-statement -Werror=implicit-function-declaration -Werror=return-type -Wstrict-prototypes -Wno-char-subscripts -Wno-unknown-pragmas -Wpointer-arith -Wunused-parameter -Wwrite-strings
build c++ flags: -D__STDC_CONSTANT_MACROS -fopenmp -msse2 -msse -pipe -fPIC -funsigned-char -fno-strict-aliasing -Wall -Wno-invalid-offsetof -Wno-sign-compare
build link flags: -pthread
build system: CMake
I see this behaviour on an Ubuntu 10.04, x86_64 system with NVidia 285.05.09 drivers. Tried with newer drivers, 290.10, but same problem.
This might be a driver issue, as I don't see this happening on a different system, which has NVidia 260.19.26 drivers.
Nobody (None) changed the task status from Unknown Status to Unknown Status.Nov 24 2011, 4:03 PM
Seems to be a driver bug, i.e. see
http://www.nvnews.net/vbulletin/showthread.php?t=164775
http://code.google.com/p/clementine-player/issues/detail?id=2113
Setting __GL_SINGLE_THREADED=1 seems to work as a work-around for me (got that one from https://bugs.gentoo.org/show_bug.cgi?id=375615)
Indeed there's posts about this bug crashing various applications. NVidia supposedly fixed an issue with this in 285.05.09, but maybe it only works when you have a newer X.org version. Moving to the OpenGL errors tracker, this is not something we can solve in Blender.
Moved from Blender 2.5 Bug Tracker to OpenGL errors
