crashing file
SVN 42175 vista 32 bits
open the file and it crashes
thanks
ok if you ope this file it dios not crahs by itsefl
by the way this happen after i tried to convert a curve to a mesh in 2.6!
here is the procedure
load up the file sugarcan then go to the file menu and open the othe file can 2562
and this will crash blender 2.6 SVN 42175
Can't reproduce crash here (windows 7, 32bit build). Can try to reproduce crash using 2.61 test build? If it'll still crash, it can help seeing your system-info.txt generated with Help -> System Info operator.
Sergey Sharybin (sergey) changed the task status from Unknown Status to Unknown Status.Nov 28 2011, 4:35 PM
sorry i;m not on widnows 7 i use vista which is not the same !
how come we cannot see the left part of this page missing like 1.2 "
cannot zoom in or out always missing !
jsut tested with 42203 and doing the same crash
did you follow the procedure i described open one file then open the second file !
where can i get this 2.61 test build
got this from window after crash
Problem signature:
Problem Event Name: APPCRASH
Application Name: blender.exe
Application Version: 2.6.0.0
Application Timestamp: 4ed3112a
Fault Module Name: ig4icd32.dll
Fault Module Version: 7.15.10.1666
Fault Module Timestamp: 49a6ea98
Exception Code: c0000005
Exception Offset: 0004a270
OS Version: 6.0.6002.2.2.0.768.3
Locale ID: 4105
Additional Information 1: fd00
Additional Information 2: ea6f5fe8924aaa756324d57f87834160
Additional Information 3: fd00
Additional Information 4: ea6f5fe8924aaa756324d57f87834160
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
does it help
Sergey,
Seems to be Intel Graphic Card again. ig4icd32.dll is the intel's driver.
so this is identified cause of intel graphic card !
i got the intel g31 G33 intel chipset !
i''ll check if i can get a new driver version
may be it will correct this ?
or is it simply that this card wont work at all ?
i mean your saying it is crashing because of the card soft not blender itself !
so nothing to stop this crashing and give an error message from blender !
but it is strange because if i load the file alone it works fine
it is only if i load from another file that it crahes !
so this looks more for me like a blender error then a Card Vid error !
if it was vid card error it will crash all the time which is not the case !
thanks
thanks
Moved from Blender 2.5 Bug Tracker to OpenGL errors
Ricky, to check updates for your videocard please go to http://downloadcenter.intel.com/ and find your video card there. It is also possible that unpacking dll from this archive http://www.graphicall.org/ftp/ideasman42/opengl32.zip and placing it near blender.exe would help.
It's indeed not much what we can do here, moving to OpenGL tracker.
i check and my driver is upadted to last version so it's ok
now i have these intel chips for a while
and i never had any crashing problems from 2.49 up to 2.55
it's only in last 2.56 that i got these crashes ounce and a while
so i still suspect something was change in 2.56 that makes the driver crash somehow
like i said this crash happen after i did a curve convert to mesh in 2.56
nay be something was wron with this convert functions in 2.56
just did a test in 42290 and re did the convert to mesh from curve and it did not crash !
the old files are probably corrupted and crashes somwhow!
thanks
