I have two files here, both very similar and one blows up Blender 2.6 series, the other doesn't.
They are parts from a model of a ship I made. There is a ship's wheel, a tiller and a tiller shape. It is something about the tiller shape that I think is causing the problem.
The ships wheel was made with a cylinder for a hub, the rim was a plane, spun 360 degrees, Each spoke was an edge loop spun 360 degrees, then dupliverted on an 8 pointed circle. The spokes were made independent objects, all objects had a simple wood image applied as a texture and then the hub, rim and spokes were joined into a single object.
The tiller is a bezier curve with two guide points. The tiller shape is a bezier circle.
Both versions work fine in Blender 2.59.
In Ships Wheel_tiller_tiller shape.blend, the tiller shape was made almost square by moving the control handles out till the vertical handles touched the horizontal handles. Blender 2.6 seems to blow up if I touch the Ship's Wheel in this version.
In Ships Wheel_tiller_tiller shape3.blend, the tiller shape was squared off by selecting all control points and handles and pressing V to set them to Vector. Blender 2.6 seems happy with this version.
How the control handles are set on the tiller shape is the only difference between the two files. Such a small variation, why does one file blow blender 2.6 up and the other doesnt?
The following thread is where I first discussed the problem and Ricky Blender confirmed that it blew up on his machine and had some information that may be of help.
http://blenderartists.org/forum/showthread.php?238674-Why-does-this-blow-up-in-2.60a&highlight=
Blows up on these two machines
Dell Inspiron ME051, Intel Celeron M 1.60 GHz, 504 MB RAM
Windows XP, Home Edition Version 2002 Service Pack 2
Dell Inspiron ME051, Intel Celeron M 1.50 GHz, 504 MB RAM
Windows XP, Home Edition Version 2002 Service Pack 3
Here's the system-info.txt for the 1.60 GHz machine.
= Blender 2.61 (sub 0) System Information =
Blender:
version 2.61 (sub 0), revision 42615. Release
build date: 2011-12-14, 13:35:50
platform: Windows:32bit
binary path: C:\Blender 2.61\blender-2.61-release-windows32\blender-2.61-release-windows32\blender.exe
build cflags: /nologo /Ob1 /J /W0 /Gd /wd4018 /wd4244 /wd4305 /wd4800 /wd4065 /wd4267 /we4013 /openmp -O2 -DNDEBUG -DWIN32 -D_CONSOLE -D_LIB -D_CRT_SECURE_NO_DEPRECATE -DWITH_MOD_FLUID -DWITH_MOD_OCEANSIM -D__LITTLE_ENDIAN__ -DWITH_AUDASPACE
build cxxflags: /nologo /Ob1 /J /W0 /Gd /wd4018 /wd4244 /wd4305 /wd4800 /wd4065 /wd4267 /we4013 /openmp /EHsc -O2 -DNDEBUG -DWIN32 -D_CONSOLE -D_LIB -D_CRT_SECURE_NO_DEPRECATE -DWITH_MOD_FLUID -DWITH_MOD_OCEANSIM -D__LITTLE_ENDIAN__ -DWITH_AUDASPACE
build linkflags: /SUBSYSTEM:CONSOLE /MACHINE:IX86 /STACK:2097152 /INCREMENTAL:NO /LARGEADDRESSAWARE /NODEFAULTLIB:msvcrt.lib /NODEFAULTLIB:msvcmrt.lib /NODEFAULTLIB:msvcurt.lib /NODEFAULTLIB:msvcrtd.lib
build system: SCons
Python:
version: 3.2 (r32:88445, Mar 4 2011, 02:13:51) [MSC v.1500 32 bit (Intel)]
paths:
C:\Blender 2.61\blender-2.61-release-windows32\blender-2.61-release-windows32\2.61\scripts\addons
C:\Blender 2.61\blender-2.61-release-windows32\blender-2.61-release-windows32\2.61\scripts\startup
C:\Blender 2.61\blender-2.61-release-windows32\blender-2.61-release-windows32\2.61\scripts\modules
C:\Blender 2.61\blender-2.61-release-windows32\blender-2.61-release-windows32\2.61\python
C:\Blender 2.61\blender-2.61-release-windows32\blender-2.61-release-windows32\python32.zip
C:\Blender 2.61\blender-2.61-release-windows32\blender-2.61-release-windows32\2.61\python\DLLs
C:\Blender 2.61\blender-2.61-release-windows32\blender-2.61-release-windows32\2.61\python\lib
C:\Blender 2.61\blender-2.61-release-windows32\blender-2.61-release-windows32\2.61\scripts\addons\modules
Directories:
scripts: ['C:\\Blender 2.61\\blender-2.61-release-windows32\\blender-2.61-release-windows32\\2.61\\scripts']
user scripts: None
datafiles: C:\Documents and Settings\Spinner Laptop003\Application Data\Blender Foundation\Blender\2.61\datafiles\
config: C:\Documents and Settings\Spinner Laptop003\Application Data\Blender Foundation\Blender\2.61\config\
scripts : C:\Documents and Settings\Spinner Laptop003\Application Data\Blender Foundation\Blender\2.61\scripts\
autosave: C:\Documents and Settings\Spinner Laptop003\Application Data\Blender Foundation\Blender\2.61\autosave\
tempdir: C:\DOCUME~1\SPINNE~1\LOCALS~1\Temp\
renderer: Intel 915GM
vendor: Intel
version: 1.4.0 - Build 4.14.10.4410
extensions:
GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_multitexture
GL_ARB_point_parameters GL_ARB_shadow GL_ARB_texture_border_clamp
GL_ARB_texture_compression GL_ARB_texture_cube_map
GL_ARB_texture_env_add GL_ARB_texture_env_combine
GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar
GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object
GL_ARB_vertex_program GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra
GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_minmax
GL_EXT_blend_subtract GL_EXT_clip_volume_hint
GL_EXT_compiled_vertex_array GL_EXT_cull_vertex
GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays
GL_EXT_packed_pixels GL_EXT_rescale_normal GL_EXT_secondary_color
GL_EXT_separate_specular_color GL_EXT_shadow_funcs
GL_EXT_stencil_two_side GL_EXT_stencil_wrap
GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add
GL_EXT_texture_env_combine GL_EXT_texture_filter_anisotropic
GL_EXT_texture3D GL_3DFX_texture_compression_FXT1
GL_IBM_texture_mirrored_repeat GL_NV_blend_square
GL_NV_texgen_reflection GL_SGIS_generate_mipmap GL_WIN_swap_hint
Does not blow up on this machine
Dell Dimension 8400, Pentium 4 CPU 3.20 GHz, 1.00 GB RAM
Windows XP, Professional Version 2002, Service Pack 2
Here's the system-info.txt for it.
Blender:
build system: SCons
Python:
paths:
Directories:
user scripts: None
datafiles: C:\Documents and Settings\Gordon Fisher\Application Data\Blender Foundation\Blender\2.61\datafiles\
config: C:\Documents and Settings\Gordon Fisher\Application Data\Blender Foundation\Blender\2.61\config\
scripts : C:\Documents and Settings\Gordon Fisher\Application Data\Blender Foundation\Blender\2.61\scripts\
autosave: C:\Documents and Settings\Gordon Fisher\Application Data\Blender Foundation\Blender\2.61\autosave\
tempdir: C:\DOCUME~1\GORDON~1\LOCALS~1\Temp\
renderer: GeForce 6800/PCI/SSE2
vendor: NVIDIA Corporation
version: 1.5.2
extensions:
GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_imaging
GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query
GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shadow
GL_ARB_shader_objects GL_ARB_shading_language_100
GL_ARB_texture_border_clamp GL_ARB_texture_compression
GL_ARB_texture_cube_map GL_ARB_texture_env_add
GL_ARB_texture_env_combine GL_ARB_texture_env_dot3
GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two
GL_ARB_texture_rectangle GL_ARB_transpose_matrix
GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader
GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float
GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add
GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color
GL_EXT_blend_equation_separate GL_EXT_blend_func_separate
GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array
GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_draw_range_elements
GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_packed_pixels
GL_EXT_pixel_buffer_object GL_EXT_point_parameters
GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D
GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map
GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine
GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic
GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp
GL_EXT_texture_object GL_EXT_vertex_array GL_HP_occlusion_test
GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat
GL_KTX_buffer_region GL_NV_blend_square GL_NV_centroid_sample
GL_NV_copy_depth_to_color GL_NV_depth_clamp GL_NV_fence
GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program
GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_half_float
GL_NV_light_max_exponent GL_NV_multisample_filter_hint
GL_NV_occlusion_query GL_NV_packed_depth_stencil
GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart
GL_NV_register_combiners GL_NV_register_combiners2
GL_NV_texgen_reflection GL_NV_texture_compression_vtc
GL_NV_texture_env_combine4 GL_NV_texture_expand_normal
GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2
GL_NV_texture_shader3 GL_NV_vertex_array_range
GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1
GL_NV_vertex_program2 GL_NV_vertex_program2_option
GL_NV_vertex_program3 GL_NVX_conditional_render
GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture
GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint
WGL_EXT_swap_control
Can't reproduce this bug here. Tried 32/64 bit linux and windows 7 platforms. Can't see any dependencies between tiler and wheel objects, so artifacts on wheel selection sounds weird. It might be opengl issue. Please try to download this soeftware driver http://graphicall.org/ftp/ideasman_42/opengl32.zip and unpack opengl32.dll to the same folder as blender.exe. It will switch blender to fully software opengl rendering. Also, if you're using builds from graphicall, try the same using official builds from blender.org.
Also, it's not actually clear how to reproduce your issue. Is it just open Ships Wheel_tiller_tiller shape.blend, select Ships Wheel object and enter edit mode?
Simply load the file and then select the ship's wheel with the RMB is what causes the problem for me. I rarely get the chance to enter edit mode, though sometimes it does take a few seconds to happen.
Pretty much sure it's issue in OpenGL. Please check if you're using the newest drivers and also check with this dll http://graphicall.org/ftp/ideasman_42/opengl32.zip unpacked to blender folder.
Moving to OpenGL bug tracker.
