crashing after working with curves in 42277
2.61 after working with curves
SVN 42722 Vista windows with intel G31-G33
After creating a bevel curve and doing some edit on it i tried to select objects in viewport and it crashes
and now i open the file and try to select an object and it always crahes!
so i went into 2.49 and did my work on the curves and it did not crashes
Windows report
Problem signature:
Problem Event Name: APPCRASH
Application Name: blender.exe
Application Version: 2.6.1.0
Application Timestamp: 4eef189a
Fault Module Name: blender.exe
Fault Module Version: 2.6.1.0
Fault Module Timestamp: 4eef189a
Exception Code: c0000005
Exception Offset: 0019f994
OS Version: 6.0.6002.2.2.0.768.3
Locale ID: 4105
Additional Information 1: fd00
Additional Information 2: ea6f5fe8924aaa756324d57f87834160
Additional Information 3: fd00
Additional Information 4: ea6f5fe8924aaa756324d57f87834160
thanks
happy blendering
Nobody (None) changed the task status from Unknown Status to Unknown Status.Dec 22 2011, 12:33 AM
Moved from Blender 2.5 Bug Tracker to OpenGL errors
Pretty much sure it's issue in OpenGL. Please check if you're using the newest drivers and also check with this dll http://graphicall.org/ftp/ideasman_42/opengl32.zip unpacked to blender folder.
Moving to OpenGL bug tracker.
cabnnot find this opengl32 thing !
can you explain where i can find this new opengl zip file at graphicall?
in which section is it in windows or another one then what ?
or can you give me a paste all link ?
thanks
happy 2.6
