Blender crashes when subdividing
Blender crashes when subdividing the defailt cube (or anything else)
Crashing at:
- default cube, enter edit and hit subdivide two (or more) times
- plane, idem
giving this dump (and more)
*** glibc detected *** blender: double free or corruption (fasttop): 0x09d71e90 ***
======= Backtrace: =========
/lib/libc.so.6(+0x6e822)[0xb5e4b822]
/lib/libc.so.6(+0x6f4c2)[0xb5e4c4c2]
/lib/libc.so.6(cfree+0x6d)[0xb5e4f5ad]
/usr/lib/libstdc++.so.6(_ZdlPv+0x1f)[0xb74aa6af]
blender(_ZNSt8_Rb_treeIPvSt4pairIKS0_jESt10_Select1stIS3_ESt4lessIS0_ESaIS3_EE5eraseERS2_+0x94)[0x89798c4]
blender(_ZN13AUD_ReferenceI11AUD_IDeviceED1Ev+0xb0)[0x8979a50]
/lib/libc.so.6(+0x30c51)[0xb5e0dc51]
/lib/libc.so.6(+0x30cdd)[0xb5e0dcdd]
/usr/lib/xorg/modules/dri/i915_dri.so(_intel_batchbuffer_flush+0x297)[0xaf7b9cb7]
/usr/lib/xorg/modules/dri/i915_dri.so(intel_flush+0x60)[0xaf7d03d0]
/usr/lib/xorg/modules/dri/i915_dri.so(intelSpanRenderStart+0x1e)[0xaf7dcd4e]
/usr/lib/xorg/modules/dri/i915_dri.so(+0x45384)[0xaf7e0384]
/usr/lib/xorg/modules/dri/i915_dri.so(+0x427a8)[0xaf7dd7a8]
/usr/lib/libdricore.so(+0x11abba)[0xaf670bba]
/usr/lib/libdricore.so(+0x11c994)[0xaf672994]
/usr/lib/libdricore.so(_tnl_run_pipeline+0x12f)[0xaf66704f]
/usr/lib/xorg/modules/dri/i915_dri.so(+0x5abba)[0xaf7f5bba]
/usr/lib/libdricore.so(_tnl_draw_prims+0x8af)[0xaf66793f]
/usr/lib/libdricore.so(_tnl_vbo_draw_prims+0x81)[0xaf667fc1]
/usr/lib/libdricore.so(vbo_exec_vtx_flush+0x550)[0xaf65d680]
/usr/lib/libdricore.so(+0x101437)[0xaf657437]
/usr/lib/libdricore.so(vbo_exec_FlushVertices+0x2f)[0xaf65b3af]
/usr/lib/libdricore.so(_mesa_PopMatrix+0x101)[0xaf5cfde1]
blender(circ+0x77)[0x836af07]
blender[0x836c2a4]
blender(view3d_main_area_draw+0x653)[0x836ff63]
blender(ED_region_do_draw+0x34c)[0x8512a8c]
blender[0x82b8a72]
blender(wm_draw_update+0xa1b)[0x82b97ab]
blender(WM_main+0x38)[0x82b8368]
blender(main+0xbf1)[0x82aece1]
/lib/libc.so.6(__libc_start_main+0xf3)[0xb5df6243]
blender[0x82b5d01]
- add a UV sphere : "segmentation fault", no other messages
Stuff does'nt need to be attached to this message, Blender dies on the default stuff...
lshw dump available upon request.
Using this:
*-cpu
product: Intel(R) Pentium(R) 4 CPU 2.66GHz
vendor: Intel Corp.
physical id: 1
bus info: cpu@0
version: 15.2.7
width: 32 bits
XFCE 4.8 on Arch Linux
Thanks
Thor
Nobody (None) changed the task status from Unknown Status to Unknown Status.Dec 23 2011, 10:58 AM
Moved from Blender 2.5 Bug Tracker to OpenGL errors
Sounds like video driver issue. Please check if there are updates for drivers and try using blender-softwaregl which will switch blender to fully software opengl and bugs in intel driver shouldn't be an issue anymore.
Will move to OpenGL tracker until it'll be confirmed it's not driver-related issue.
Thanks for the input, glad to be around...
Sorry, folks. I located the script in question, put it in my path, fired it up and got the same result...
Will attempt (if I can find the precious time, that is) to do a sysup today...
Thor
Update done, still the same result. I'm beginning to think there's something wrong with the box itself...maybe something in my config that Blender does not like too much (at all)
