Why contents of window Blender 2.61 become grey?
= Blender 2.61 (sub 0) System Information =
Blender:
version 2.61 (sub 0), revision 42615. Release
build date: 2011-12-14, 13:35:50
platform: Windows:32bit
binary path: C:\Blender Foundation\Blender\blender.exe
build cflags: /nologo /Ob1 /J /W0 /Gd /wd4018 /wd4244 /wd4305 /wd4800 /wd4065 /wd4267 /we4013 /openmp -O2 -DNDEBUG -DWIN32 -D_CONSOLE -D_LIB -D_CRT_SECURE_NO_DEPRECATE -DWITH_MOD_FLUID -DWITH_MOD_OCEANSIM -D__LITTLE_ENDIAN__ -DWITH_AUDASPACE
build cxxflags: /nologo /Ob1 /J /W0 /Gd /wd4018 /wd4244 /wd4305 /wd4800 /wd4065 /wd4267 /we4013 /openmp /EHsc -O2 -DNDEBUG -DWIN32 -D_CONSOLE -D_LIB -D_CRT_SECURE_NO_DEPRECATE -DWITH_MOD_FLUID -DWITH_MOD_OCEANSIM -D__LITTLE_ENDIAN__ -DWITH_AUDASPACE
build linkflags: /SUBSYSTEM:CONSOLE /MACHINE:IX86 /STACK:2097152 /INCREMENTAL:NO /LARGEADDRESSAWARE /NODEFAULTLIB:msvcrt.lib /NODEFAULTLIB:msvcmrt.lib /NODEFAULTLIB:msvcurt.lib /NODEFAULTLIB:msvcrtd.lib
build system: SCons
Python:
version: 3.2 (r32:88445, Mar 4 2011, 02:13:51) [MSC v.1500 32 bit (Intel)]
paths:
C:\Blender Foundation\Blender\2.61\scripts\addons
C:\Blender Foundation\Blender\2.61\scripts\startup
C:\Blender Foundation\Blender\2.61\scripts\modules
C:\Blender Foundation\Blender\2.61\python
C:\Blender Foundation\Blender\python32.zip
C:\Blender Foundation\Blender\2.61\python\DLLs
C:\Blender Foundation\Blender\2.61\python\lib
C:\Blender Foundation\Blender\2.61\scripts\addons\modules
Directories:
scripts: ['C:\\Blender Foundation\\Blender\\2.61\\scripts']
user scripts: None
datafiles: C:\Documents and Settings\Администратор\Application Data\Blender Foundation\Blender\2.61\datafiles\
config: C:\Documents and Settings\Администратор\Application Data\Blender Foundation\Blender\2.61\config\
scripts : C:\Documents and Settings\Администратор\Application Data\Blender Foundation\Blender\2.61\scripts\
autosave: C:\Documents and Settings\Администратор\Application Data\Blender Foundation\Blender\2.61\autosave\
tempdir: C:\DOCUME~1\9335~1\LOCALS~1\Temp\
renderer: ATI Radeon 9600/9550/X1050 Series
vendor: ATI Technologies Inc.
version: 2.1.8545 Release
extensions:
GL_AMD_performance_monitor GL_ARB_depth_texture GL_ARB_draw_buffers
GL_ARB_fragment_program GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader GL_ARB_framebuffer_object
GL_ARB_half_float_pixel GL_ARB_half_float_vertex
GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture
GL_ARB_occlusion_query GL_ARB_pixel_buffer_object
GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shader_objects
GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_shadow_ambient
GL_ARB_texture_border_clamp GL_ARB_texture_compression
GL_ARB_texture_cube_map GL_ARB_texture_env_add
GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3 GL_ARB_texture_float
GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two
GL_ARB_texture_rectangle GL_ARB_transpose_matrix
GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object
GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos
GL_ATI_draw_buffers GL_ATI_envmap_bumpmap GL_ATI_fragment_shader
GL_ATI_meminfo GL_ATI_separate_stencil GL_ATI_texture_env_combine3
GL_ATI_texture_float GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color
GL_EXT_blend_equation_separate GL_EXT_blend_func_separate
GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array
GL_EXT_copy_texture GL_EXT_draw_range_elements GL_EXT_fog_coord
GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample
GL_EXT_framebuffer_object GL_EXT_gpu_program_parameters
GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil
GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal
GL_EXT_secondary_color GL_EXT_separate_specular_color
GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_EXT_subtexture
GL_EXT_texgen_reflection GL_EXT_texture3D
GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map
GL_EXT_texture_edge_clamp GL_EXT_texture_env_add
GL_EXT_texture_env_combine GL_EXT_texture_env_dot3
GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias
GL_EXT_texture_mirror_clamp GL_EXT_texture_object
GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_swizzle
GL_EXT_vertex_array GL_KTX_buffer_region GL_NV_blend_square
GL_NV_texgen_reflection GL_SGIS_generate_mipmap
GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_WIN_swap_hint
WGL_EXT_swap_control
It's totally lag of information in this report. Please follow bug report guidelines and provide exact steps of reproducing the issue, behavior you've got and behavior you're expecting. Also provide version of operation system and CPU.
From this short information i might guess that issue is related on video driver. Make sure you're using the very recent official drivers from ati site.
System: Windows XP sp3
Proz: AMD Athlon(tm) 64 3000+
Blender 2.49 works without problems. Drivers has put new from site ATI.
Посмотрите пожалуйста, вот здесь скрин: http://blenderartists.org/forum/showthread.php?240718-Why-contents-of-window-Blender-2.61-become-grey&daysprune=1
This does not help. We can only speculate.
It looks like it might be a path issue.
Try to copy the whole blender folder to C:\ or so, and start from there.
On second look, it does not look like an issue with missing scripts (3D View headers are there)
I suspect an OpenGL issue, your card is quite ancient.
Moved from Blender 2.5 Bug Tracker to OpenGL errors
You might want to download this archive graphicall.org/ftp/ideasman42/opengl32.zip unpack and place opengl32.dll to the same directory as blender.exe and try to use blender again. It'll switch blender to fully software mode.
Blender switched to use opengl much more intensive since 2.49 and this issue might be caused by crappy video card/video driver.
Also, would be interesting to know if it might be reproduced on other computers/systems.
Pretty much sure it's OpenGL issue, so moving to it's own tracker.
A problem has solved. Was ATI 10.1, has put ATI 7.11. Now all works! Thank you !
Sergey Sharybin (sergey) changed the task status from Unknown Status to Unknown Status.Dec 29 2011, 4:01 PM
