windows SVN 43085
32 bits vista
ok i can open this file with defaults
but if i try to open without load UI then it crashes all the time!
Problem signature:
Problem Event Name: APPCRASH
Application Name: blender.exe
Application Version: 2.6.1.0
Application Timestamp: 4f022a35
Fault Module Name: ig4icd32.dll
Fault Module Version: 7.15.10.1666
Fault Module Timestamp: 49a6ea98
Exception Code: c0000005
Exception Offset: 0004a270
OS Version: 6.0.6002.2.2.0.768.3
Locale ID: 4105
Additional Information 1: 55dc
Additional Information 2: bef48b4a78a784a295aacaf5fd373e0f
Additional Information 3: ec6b
Additional Information 4: 7de8543035b3d11bc2e082438cb9ed01
thanks
Sounds like a bug in intel drivers. Make sue you're using th very recent drivers from official intel's download center.
If it'll continue to crash for you, please provide sample .blend file and fuller system specification (operation system, version, bitenss, system-info.txt generated by Help -> System Information operator).
windows SVN 43085
32 bits vista
the page on system info contains a lot of personnel password
and cannot upload in public place here !
and it is 800 KB !
which fields do you need ?
i have latest of most soft on my system!
been check 2 weeks ago i think
sorry i did upload the file but looks like it was lost!
and don't think this is realated to intel soft itself
but more may be with some sort openCL
problem like it was indicated on last file crashes bug report
cause i never had problem before with 2.49 on same machine and blender!
so suspect it is something else the intel driver !
only common problem i see here is that i appended objects (font + mesh) from a 2.49 file to 2.6
and that's where problems happened!
i mean it works fine in 2.49 why not in 2.6 !
it's using the same intel driver but not the same blender driver interface!
now this one crashe sonly if i open it up while setting load GUI off
it works fine if i don't use this feature (load GUI)
which is very strange !
hope you can ID it
thanks guys
sorry file is 5.05 MB and tried compress and it does not work
file stays same size
and it is being refuse !
i got nothing in this file why so big !
got to find another place to upload it and give you a URL
salutations
I'm not sure what personal information you're talking about, system-info.txt generated by operator from blender's Help -> System Iformation should not contain such information. But without knowing windos version, bitness and details about OpenGL is used in your system we can't figure out the problem. In additional to operation system version and system-info.txt it's needed to know your videocard model.
Blender 2.5x and newer is using opengl much more intensively and this explains why 2.49 works and 2.61 crashes for you. It's not actually much what can be done from our side unfortunately, intelis known for it's crappy hardware and drivers which makes blender crashing. It's not because of bugs from our side, but because of specific of how intel drivers are working.
If you're using 32bit version of blender. you can try downloading this archive graphicall.org/ftp/ideasman_42/opengl32.zip unpacking opengl32.dll to the same directory as blender.exe and running blender. It will switch blender to software mode. There's one known issue with this mdde -- o the blender exit it tells that blender crashed. It's annoying, but not leading to data loose and it's a bit difficult to figre out why it happens.
ok try it here
https://skydrive.live.com/#cid=348AD7D85DEE0C79&id=348AD7D85DEE0C79%21204
it is public share
so you should be able to download the greek alphabet file from this folder
have fun
happy 2.6
sorry i tought you meant windows system info file !
here it is for blender
= Blender 2.61 (sub 0) System Information =
Blender:
version 2.61 (sub 0), revision 43210. Release
build date: 2012-01-07, 00:31:12
platform: Windows:64bit
binary path: C:\Users\RJ\0blend25\0beta43210\blender_win32_43210_opt\blender.exe
build cflags: /nologo /J /W1 /Gd /we4013 /wd4018 /wd4244 /wd4305 /wd4800 /wd4065 /wd4267 /openmp -DNDEBUG -DWIN32 -D_CONSOLE -D_LIB -D_CRT_SECURE_NO_DEPRECATE -DWITH_MOD_FLUID -DWITH_MOD_OCEANSIM -D__LITTLE_ENDIAN__ -DWITH_AUDASPACE
build cxxflags: /nologo /J /W1 /Gd /we4013 /wd4018 /wd4244 /wd4305 /wd4800 /wd4065 /wd4267 /openmp /EHsc -DNDEBUG -DWIN32 -D_CONSOLE -D_LIB -D_CRT_SECURE_NO_DEPRECATE -DWITH_MOD_FLUID -DWITH_MOD_OCEANSIM -D__LITTLE_ENDIAN__ -DWITH_AUDASPACE
build linkflags: /SUBSYSTEM:CONSOLE /MACHINE:IX86 /STACK:2097152 /INCREMENTAL:NO /LARGEADDRESSAWARE /NODEFAULTLIB:msvcrt.lib /NODEFAULTLIB:msvcmrt.lib /NODEFAULTLIB:msvcurt.lib /NODEFAULTLIB:msvcrtd.lib
build system: SCons
Python:
version: 3.2 (r32:88445, Mar 4 2011, 02:13:51) [MSC v.1500 32 bit (Intel)]
paths:
C:\Users\RJ\0blend25\0beta43210\blender_win32_43210_opt\2.61\scripts\addons_contrib
C:\Users\RJ\0blend25\0beta43210\blender_win32_43210_opt\2.61\scripts\startup
C:\Users\RJ\0blend25\0beta43210\blender_win32_43210_opt\2.61\scripts\modules
C:\Users\RJ\0blend25\0beta43210\blender_win32_43210_opt\2.61\python
C:\Users\RJ\0blend25\0beta43210\blender_win32_43210_opt\python32.zip
C:\Users\RJ\0blend25\0beta43210\blender_win32_43210_opt\2.61\python\DLLs
C:\Users\RJ\0blend25\0beta43210\blender_win32_43210_opt\2.61\python\lib
C:\Users\RJ\0blend25\0beta43210\blender_win32_43210_opt\2.61\scripts\addons\modules
Directories:
scripts: ['C:\\Users\\RJ\\0blend25\\0beta43210\\blender_win32_43210_opt\\2.61\\scripts']
user scripts: None
datafiles: C:\Users\RJ\AppData\Roaming\Blender Foundation\Blender\2.61\datafiles\
config: C:\Users\RJ\AppData\Roaming\Blender Foundation\Blender\2.61\config\
scripts : C:\Users\RJ\AppData\Roaming\Blender Foundation\Blender\2.61\scripts\
autosave: C:\Users\RJ\AppData\Roaming\Blender Foundation\Blender\2.61\autosave\
tempdir: C:\Users\RJ\AppData\Local\Temp\
FFmpeg:
avcodec: 53, 42, 0
avdevice: 53, 4, 0
avformat: 53, 24, 0
avutil: 51, 32, 0
swscale: 2, 1, 0
renderer: Intel Bear Lake B
vendor: Intel
version: 1.4.0 - Build 7.15.10.1666
extensions:
GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color
GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint
GL_EXT_compiled_vertex_array GL_EXT_cull_vertex
GL_SGIS_texture_edge_clamp GL_SGIS_generate_mipmap
GL_EXT_draw_range_elements GL_SGIS_texture_lod GL_EXT_rescale_normal
GL_EXT_packed_pixels GL_EXT_separate_specular_color
GL_ARB_multitexture GL_EXT_texture_env_combine GL_EXT_bgra
GL_EXT_blend_func_separate GL_EXT_secondary_color GL_EXT_fog_coord
GL_EXT_texture_env_add GL_ARB_texture_cube_map GL_ARB_transpose_matrix
GL_ARB_texture_env_add GL_IBM_texture_mirrored_repeat
GL_EXT_multi_draw_arrays GL_NV_blend_square GL_ARB_texture_compression
GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic
GL_ARB_texture_border_clamp GL_ARB_point_parameters
GL_ARB_texture_env_combine GL_ARB_texture_env_dot3
GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc
GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs
GL_EXT_stencil_wrap GL_ARB_vertex_program GL_ARB_fragment_program
GL_EXT_stencil_two_side GL_ARB_vertex_buffer_object
GL_EXT_texture_lod_bias GL_NV_texgen_reflection GL_ARB_depth_texture
GL_WIN_swap_hint
but as i explain i can open the file normaly and it works fine
it crashes only if i open with no load GUI?
it works in one case but not in the ohter case!
one question from the blender sys info
why does it says that it is 64 bits while l'm on a 32 bits vista machine ?
thanks
OpenGl issues are always inpredictable. It's indeed the very recent drivers installed, so the only way to test would be try to use graphicall.org/ftp/ideasman42/opengl32.zip unpacked to the same folder as blender.exe.
Can't reproduce crash on my laptop with intel videocard. Will keep asking other developers to try to reproduce the issue. Unfortunately, it's not much we can do in this situation, it's just bug in library we aren't developing. Moving to OpenGL tracker.
P.S. It's indeed interesting question about bitness.
