VSE Deinterlace+render=wrong audio data
Relates to Sequencer and Renderer
Blender 2.61
Windows Vista SP2
If a portion of an video with audio clip is cut, deinterlaced, and then rendered, the audio will become incorrect, as if the data block shifts.
1. Open a video strip with audio.
2. Cut a segment from the middle of the audio and video strip.
3. Select the video strip and check "deinterlace" in the properties panel.
4. Click play in the timeline and the correct audio should play with your cut clip.
5. NOW, go to the rendering panel, select h.264 video with mp2 audio.
6. Render clip and listen to the audio. It should be different from what you heard in step 4.
7. Go back to the timeline and click play and you will notice the audio segment is different.
Can’t reproduce any bug here (neither with 2.61 nor with 44097, debian testing)…
Can Peter check on this?
we need some additional things, to investigate this:
- an input file to test
- did you use timecode indices?
The later most probably will fix the problem, since seeking is more or less non working (depending on the container format you haven't mentioned),
if you don't build a timecode index.
Cheers,
Peter
Since we haven't heard much, closing this for now.
Please reopen, if you have some example files for us.
Cheers
Peter
Peter Schlaile (schlaile) changed the task status from Unknown Status to Archived.Apr 15 2012, 2:44 PM
