Grid Cap fills a hole with a grid of faces
Closed, ResolvedPublicPATCH
Project: Blender Extensions
Tracker: Py Scripts Upload
Blender: 2.61
Category: Mesh
Python: 3.2
Script name: Grid Cap
Wiki page: http://wiki.blender.org/index.php/Extensions:2.6/Py/Scripts/Modeling/grid_cap
Author(s): Lell
Status: Open
This add-on allows to fill a hole with many sides with a grid of faces, taking into account the shape of the border. To create the grid is necessary to select the entire border, and if necessary, deselect the vertices you want to be used as corners of the grid. Than press CTRL-F and select Grid Cap to fill the hole. In case of strange borders or heavy mesh, hide everything but the border, deselect the corners and run the script.
For complete explanation watch the instructions video at http://youtu.be/QEaln30pjxA
This is the wiki page http://wiki.blender.org/index.php/Extensions:2.6/Py/Scripts/Modeling/grid_cap
Hi,
Due to changes to the api including the merging of bmesh, several addons are outdated.
Please, if you are the author of an addon check your script with blender revision 44256 or newer.
That is builds made After blender 2.62 official release.
I would ask that updates be made to your addon before the Blender 2.63 release.
6-8 weeks away.
This allows time for the api to become more exposed & bmesh to stablize furthur.
If you need help, drop into irc freenode #blenderpython or #blendercoders & feel welcome to ask questions.
At the time of 2.63 release, scripts that are not repaired or in active developement will have their tracker page marked "Closed"
this will not affect your links to the tracker, similar to closing scripts in 2.49b, the page will be still availible & can be re-opened.
Thanks for your understanding & patience during these Exciting Times.
Brendon.
Brendon Murphy (meta-androcto) changed the task status from Unknown Status to Resolved.Sep 1 2015, 4:14 PM
Closing as resolved, function is in Blender
