Win7 Ultimate 64bit
2.62
r45265
When opening a blend file by dragging it onto the desktop app icon, while the filename or filepath contains utf characters ( like chinese), it works fine in earlier build, but never got it work with latest build. Fyi.
PS: I found it works fine with Ubuntu 11.10. However, I'm afraid it just doesn't work with Win7 so far. And never got a chance to test with Mac OS yet.
Cannot confirm with r45318
Can you give filepaths that you are using
Also can you run "blender.exe -d" and then Help->Toggle Console to see debug output.
Thank you
please see attachment.
the error screenshot2.jpg occurs, when dragging the file into the opened window.
Comment:
I've just been infomed by another local friend, who met the similar problem. He just open the blend file normally as usual, by loading from "File -> Open" menu. Confirmed myself with 45317, win7 64bit. FYI. Thank you.
Elubie and I cannot replicate it.
I'm afraid that it might be corrupt UTF with illegal symbols when you drag.
Can you
right click blender shortcut
Properties->Shortcut
Target: change "***/blender.exe" to "***/blender.exe -d"
Drag the same file onto shortcut
In blender:
Help->Toggle System Console
Right click on title bar of console
Edit->Mark
Select
Enter (will copy)
And paste the output here
Thanks
Blender 2.62 (sub 3)
Build: Sun 04/01/2012 07:07 AM Windows
argv[0] = E:\b-ver\120401_6652_win7.x64-45317\Win7.x64-45317\blender.exe
argv[1] = -d
argv[2] = D:\鏂板缓鏂囦欢澶筡jump to cut test.blend
read file C:\Users\LK\AppData\Roaming\Blender Foundation\Blender\2.62\config\sta
rtup.blend
Version 262 sub 3 svn r45317
ordered
OBCube
OBLamp
OBCamera
found bundled python: E:\b-ver\120401_6652_win7.x64-45317\Win7.x64-45317\2.62\py
thon
read file
Version 258 sub 1 svn r0
Can't read file: "D:\鏂板缓鏂囦欢澶筡jump to cut test.blend", Unable to open the
file.
recalcob Cube
recalcdata Cube
Please see above. That's all I have by following your way.
PS: The File path here seems quite strange, the foler name in console shows "D:\鏂板缓鏂囦欢澶筡jump to cut test.blend". However, I bet the correct and "readable" one should be "D:\新建文件夹\jump to cut test.blend".
And below are what displayed there when "International Fonts" is toggled on
or see attachments Thanks.
argv[1] = -d
rtup.blend
ordered
OBCube
OBLamp
OBCamera
thon
read file
Can't read file: "D:\?–°??o?–?????¤1\jump to cut test.blend", Unable to open
the file.
recalcob Cube
recalcdata Cube
Leon, can you please re-check with a new SVN version from here please: http://builder.blender.org/download/ ?
Closing due to no response from the bug reporter. (Also could not be verified by 2 developers)
Sorry for very late confirmation on this, Dingto. I'm afraid such issue stil exists with 2.64 rc2.
