Selecting compress .blends issues a "failed opening .gz file" in 2.63 testbuild1
A .blend file is not needed I think because it happens even on a fresh install and default scene (deleted temporal user and application data folders) of the 2.63 testbuild1,
do :
1) in default startup, go "user preferences" select FILE tab and tick the "compress" files on Save/load menus
2) on the current scene choose "save as..." save
3) a pop up appears "failed opening .gz file" and the result is a -compressed?- file with a ampersand "@" at the .blend extension ( eg. untitled.blend@ )
I think that resulting file loads okay, but, I´m worried about data corruption, in much more complex project files...
You can avoid this by simply unticking the mentioned "compress" flag
As far as I can tell this happens in SVN r 45393+ and 2.63 testbuild1 , and pretty sure NOT in 2.62 svn 45000+ with MiikaH builds (dynamic paint dev)
happened on XP, dont know other systems.
System :
winXP 32 bit
2gb RAM
if you need more info just ask...
Hi,
thanks for the report, but this has already been reported: http://projects.blender.org/tracker/index.php?func=detail&aid=30618&group_id=9&atid=498
>> Closing
Thomas Dinges (dingto) changed the task status from Unknown Status to Archived.Apr 6 2012, 10:43 PM
