iMac Haven't been able to start the last 2 test versions
Problem Report:
Process: blender [424]
Path: /Users/phampton/Downloads/blender-2.63-testbuild2-OSX_10.5_i386/blender.app/Contents/MacOS/blender
Identifier: org.blenderfoundation.blender
Version: ??? (???)
Code Type: X86 (Native)
Parent Process: launchd [102]
Haven't been able to start/open the last 2 test versions. I have:
Model Name: iMac
Model Identifier: iMac9,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.66 GHz
Number Of Processors: 1
Total Number Of Cores: 2
REPORT PRINTOUT after trying to open the program:
Interval Since Last Report: 276241 sec
Crashes Since Last Report: 25
Per-App Interval Since Last Report: 0 sec
Per-App Crashes Since Last Report: 21
Date/Time: 2012-04-17 09:47:23.583 -0700
OS Version: Mac OS X 10.5.8 (9L31a)
Report Version: 6
Anonymous UUID: 19FC7D76-842A-47AD-8864-FB0707810738
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread: 0
Dyld Error Message:
Symbol not found: __ZNKSt9bad_alloc4whatEv
Referenced from: /Users/phampton/Downloads/blender-2.63-testbuild2-OSX_10.5_i386/blender.app/Contents/MacOS/blender
Expected in: /usr/lib/libstdc++.6.dylib
I'm not savvy enough to know what this means.
Jens, do you have any ideas here?
Hi
Either osx 10.5 has not the right stdlib ( version ) as i linked or the 10.5 deployment fails at some point.
Attched is a testbuild same as 2.63 rc1 but with only static stdlib from gcc 4.6.3.
Pls test: http://www.jensverwiebe.de/Blender/blender_test_stdlib.zip
Jens
Still won't launch. I also tried relaunching and reset then relaunch.
Here's the report:
Process: blender [1725]
Path: /Non-Syncing/blender.app/Contents/MacOS/blender
Identifier: blender
Version: ??? (???)
Interval Since Last Report: 25144 sec
Crashes Since Last Report: 4
Per-App Crashes Since Last Report: 3
Date/Time: 2012-04-18 08:14:43.846 -0700
Report Version: 6
Crashed Thread: 0
Dyld Error Message:
Symbol not found: ___emutls_get_address
Referenced from: /Non-Syncing/blender.app/Contents/MacOS/blender
Expected in: /usr/lib/libgcc_s.1.dylib
Thanks,
Pam
o.k., i see thats due compiling with gnu compiler ( for having intact openMP ) which seems not to behave like apple compiler.
I must compile next builds again with former configuration.
Stay tuned.
Jens
Hi Pam
To test again if i can do 10.5 builds on Lion, i made a new testbuild with apple compiler.
In theory, this should now work but has no openMP enabled.
I this works, it would spare me a lot of time always rebooting into SnowLeo for this.
Pls try to open: http://www.jensverwiebe.de/Blender/blender_deploy_10.5_test2.zip
Jens
Sorry, no go. Here's the latest report:
Process: blender [5129]
Identifier: blender
Version: ??? (???)
Interval Since Last Report: 34209 sec
Date/Time: 2012-04-19 09:11:12.660 -0700
Report Version: 6
Crashed Thread: 0
Dyld Error Message:
0kay ( or not so to say )
I will go back to former state and must compile on 10.6 against 10.5 sdk like all releases where done.
Pity, something must be special here.
Thanks for testing Pam, expect next rc in old style, so working again.
Jens
wouldn't statically linking against libgcc fix this?
I guess this can be closed now, assuming 2.63 release was built in the way that it worked before.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved.May 3 2012, 6:11 PM
Yes, you can close it. 2.63 release seems to be working fine. . . except for some issues in the video sequencer that others have reported.
