VSE Audio keyframes disappear on copy>paste
After copying and pasting a meta strip with audio (from .mov camera file), I find that the newly pasted meta-strip's audio keyframes disappear. BUT they swap over to the video strip, as audio keyframes? See .jpg
win XP b2.63 r46094
Copy-paste doesn't actually copies curves assigned to strips, it's only copies strips themselves. It might be improved, but it's not a bug.
Actual bug here is that you somehow managed to create two strips with the same name which shouldn't normally happen. And to fix actual bug i'm wondering how you managed to do this and if you're able to reproduce this in a scene created in 2.63 release from scratch.
P.S. As workaround you might rename one of this two strips.
Closed issue caused by the same issue http://projects.blender.org/tracker/index.php?func=detail&aid=31186&group_id=9&atid=498
No response in more than week. Will close the report. When steps to re-produce two strips with the same name would be known it'll be easy to fix.
Sergey Sharybin (sergey) changed the task status from Unknown Status to Archived.May 10 2012, 1:47 PM
