Exiting Texture Paint mode cause model to become black
I'm on Windows 7 x64 and I'm using Blender 2.63a x64.
When I exit Texture Paint mode it cause models to become black. And it stays like this until I reload the texture or the .blend. Also when I use a brush after the model becomes black the textures kind of return but they are in shades of grey.
I've attached a model to experiment with.
can't redo this bug, could you include info about your graphics card? (help, system info)
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Unknown Status.May 12 2012, 11:43 AM
I have the Radeon HD 6790.
Shader units : 800
ROPs : 16
GPU : Barts
Transistors : 1700M
Memory Size : 1024 MB
Memory Bus Width : 256 bit
Core Clock : 840 MHz
Memory Clock : 1050 MHz
Moved from Blender 2.6 Bug Tracker to OpenGL errors
This is very likely a driver bug - suggest you try update the graphics card drivers and see if this resolves the bug.
