crash when selecting objects
With the current CVS release of blender, selecting an object causes weird
lines to appear all over the screen (and these lines disappear when the mouse
cursor is moved to a different panel) or a crash (when the selected object
is the camera, the crash is almost obligatory).
I have been experiencing this on a Linux notebook with an ATI graphical
card (Chipset: "ATI Radeon IGP320M (U1) 4336" (ChipID = 0x4336) - I know
this is not so high-end... my notebook is not brand new... but that's enough
for low-poly models).
Since I have not been experiencing this with my desktop (Linux as well,
the card is an NVIDIA 6600GT),
I suspect that the graphical card and/or drivers are involved,
I append the the output of 'glxinfo' at the end of the report.
Just tell if more information is needed.
Cheers,
name of display: :0.0
Loading required GL library /usr/X11R6/lib/libGL.so.1.2
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_EXT_import_context, GLX_OML_swap_method, GLX_SGI_make_current_read,
GLX_SGIS_multisample, GLX_SGIX_fbconfig
client glx vendor string: SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory,
GLX_MESA_swap_control, GLX_MESA_swap_frame_usage, GLX_OML_swap_method,
GLX_OML_sync_control, GLX_SGI_make_current_read, GLX_SGI_swap_control,
GLX_SGI_video_sync, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group
GLX extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_swap_control,
GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_SGI_video_sync,
OpenGL vendor string: Tungsten Graphics, Inc.
OpenGL renderer string: Mesa DRI Radeon 20050528 AGP 4x x86/MMX+/3DNow!+/SSE NO-TCL
OpenGL version string: 1.2 Mesa 6.3.1
OpenGL extensions:
GL_ARB_imaging, GL_ARB_multisample, GL_ARB_multitexture,
GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
GL_ARB_texture_mirrored_repeat, GL_ARB_texture_rectangle,
GL_ARB_transpose_matrix, GL_ARB_window_pos, GL_EXT_abgr, GL_EXT_bgra,
GL_EXT_blend_color, GL_EXT_blend_logic_op, GL_EXT_blend_minmax,
GL_EXT_blend_subtract, GL_EXT_clip_volume_hint,
GL_EXT_compiled_vertex_array, GL_EXT_convolution, GL_EXT_copy_texture,
GL_EXT_draw_range_elements, GL_EXT_histogram, GL_EXT_packed_pixels,
GL_EXT_polygon_offset, GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_stencil_wrap, GL_EXT_subtexture,
GL_EXT_texture, GL_EXT_texture3D, GL_EXT_texture_edge_clamp,
GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_vertex_array,
GL_APPLE_packed_pixels, GL_ATI_texture_env_combine3,
GL_ATI_texture_mirror_once, GL_IBM_rasterpos_clip,
GL_IBM_texture_mirrored_repeat, GL_MESA_ycbcr_texture, GL_MESA_window_pos,
GL_NV_blend_square, GL_NV_light_max_exponent, GL_NV_texture_rectangle,
GL_NV_texgen_reflection, GL_OES_read_format, GL_SGI_color_matrix,
GL_SGI_color_table, GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod
glu version: 1.3
glu extensions:
GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x23 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x24 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x25 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x26 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x27 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x28 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x29 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x2a 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x2b 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x2c 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x2d 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x2e 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x2f 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x30 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x31 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x32 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
Logged In: YES
user_id=103
Hi,
First of all check if this happens on older releases, like 2.37a. If this error recently happened, we might be able to do something. But your descriptions smells like a driver issue yes....
BTW; did it ever work OK? And if so, did you upgrade things?
Logged In: YES
user_id=4200
Well, things used to work rather good on that laptop, but at about the same
time I moved to CVS (blender 2.36 I think), I upgraded a couple of things and
ended up with new(er) versions of xorg and friends (GLU, GLUT, Mesa), as well
as gcc (now 4.0).
I compiled a fresh 2.37a and... well, it does show the same problems :(.
This could very well be a driver thing (this ATI card gave me so much trouble !). I ran the thing through 'ltravce' and I append the last lines I get
before the segfault/core dumped (it looks like this is at the openGL
level... no clue why it crashes after quite a few calls to the same function).
glVertex3fv(0x89f5178, 0x878eac0, 0xbf9fe658, 0xb7c4d6a7, 2305) = 5
glVertex3fv(0x89f518c, 0x878eac0, 0xbf9fe658, 0xb7c4d6a7, 2305) = 4
glVertex3fv(0x89f5024, 0x878eac0, 0xbf9fe658, 0xb7c4d6a7, 2305) = 3
glVertex3fv(0x89f51a0, 0x878eac0, 0xbf9fe658, 0xb7c4d6a7, 2305) = 2
glVertex3fv(0x89f518c, 0x878eac0, 0xbf9fe658, 0xb7c4d6a7, 2305) = 1
glVertex3fv(0x89f51a0, 0x878eac0, 0xbf9fe658, 0xb7c4d6a7, 2305 <unfinished ...>
--- SIGSEGV (Segmentation fault) ---
+++ killed by SIGSEGV +++
I guess that I have pushed the "bug" button to quickly...
Thanks.
RM
PS: the bonus question: why going for the CVS version ?. Well, I have to live
on the edge now and then... and I was curious about the fuild simulation stuff...
Logged In: YES
user_id=4200
The problem has been reported elsewhere, for the same graphical card
(ATI Radeon Mobility M6):
http://www.ubuntuforums.org/showthread.php?t=72720&highlight=blender
Logged In: YES
user_id=103
Hi,
We cannot support here own compilations... for that we have developer forums and mailing lists!
Try official builds, all versions are on download.blender.org
We make an official test build for everyone this week too!
I've been having that same type of crash on my macbook. It seems to happen very randomly when i move the cursor. Lines and then crash. I've got a dual core intel mac with a
GMA X3100 graphics card. I'm so sad without blender please help...
Matt Ebb (broken) changed the task status from Unknown Status to Unknown Status.Mar 26 2010, 6:15 AM
