sequencer image preview blank
the sequencer shows a blank (white) image when showing any kind of image data (like pictures or videos), it is not the same as #20567, because i can grab to move and zoom the preview, it just shows all white, even when a proxy is generated, and also with all kind of preview types (chroma, histogram, etc...), blender also slows down alot when the current playback is at any image/video sequence, the audio can be heard and the render works fine, the problem is just the preview
This isn't happening in blender 2.49 but it does happen in blender 2.59 and 2.63a
system:
windows 7 32 bits (for some reason blender claims that my system is 64 bits...)
= Blender 2.59 (sub 0) System Information =
Blender:
version 2.59 (sub 0), revision 39307. Release
build date: 2011-08-13, 11:44:03
platform: Windows:64bit (32 bits really....)
binary path: C:\Program Files\Blender Foundation\Blender\blender.exe
build cflags: /nologo /Ob1 /J /W0 /Gd /wd4018 /wd4244 /wd4305 /wd4800 /wd4065 /wd4267 /we4013 /openmp -DWITH_AUDASPACE -O2 -DNDEBUG -O2 -DNDEBUG -DWIN32 -D_CONSOLE -D_LIB -D_CRT_SECURE_NO_DEPRECATE /openmp -DWITH_AUDASPACE
build cxxflags: /nologo /Ob1 /J /W0 /Gd /wd4018 /wd4244 /wd4305 /wd4800 /wd4065 /wd4267 /we4013 /openmp -DWITH_AUDASPACE /EHsc /openmp -DWITH_AUDASPACE -O2 -DNDEBUG -O2 -DNDEBUG -DWIN32 -D_CONSOLE -D_LIB -D_CRT_SECURE_NO_DEPRECATE /openmp -DWITH_AUDASPACE
build linkflags: /SUBSYSTEM:CONSOLE /MACHINE:IX86 /STACK:2097152 /INCREMENTAL:NO /LARGEADDRESSAWARE /NODEFAULTLIB:msvcrt.lib /NODEFAULTLIB:msvcmrt.lib /NODEFAULTLIB:msvcurt.lib /NODEFAULTLIB:msvcrtd.lib
build system: SCons
Python:
version: 3.2 (r32:88445, Mar 4 2011, 02:13:51) [MSC v.1500 32 bit (Intel)]
paths:
C:\Program Files\Blender Foundation\Blender\2.59\scripts\addons
C:\Program Files\Blender Foundation\Blender\2.59\scripts\startup
C:\Program Files\Blender Foundation\Blender\2.59\scripts\modules
C:\Program Files\Blender Foundation\Blender\2.59\python
C:\Program Files\Blender Foundation\Blender\python32.zip
C:\Program Files\Blender Foundation\Blender\2.59\python\DLLs
C:\Program Files\Blender Foundation\Blender\2.59\python\lib
C:\Program Files\Blender Foundation\Blender\2.59\scripts\addons\modules
Directories:
scripts: ['C:\\Program Files\\Blender Foundation\\Blender\\2.59\\scripts']
user scripts: None
datafiles: C:\Users\Rafael\AppData\Roaming\Blender Foundation\Blender\2.59\datafiles\
config: C:\Users\Rafael\AppData\Roaming\Blender Foundation\Blender\2.59\config\
scripts : C:\Users\Rafael\AppData\Roaming\Blender Foundation\Blender\2.59\scripts\
autosave: C:\Users\Rafael\AppData\Roaming\Blender Foundation\Blender\2.59\autosave\
tempdir: C:\Users\Rafael\AppData\Local\Temp\
renderer: GDI Generic
vendor: Microsoft Corporation
version: 1.1.0
extensions:
GL_WIN_swap_hint GL_EXT_bgra GL_EXT_paletted_texture
gpu: intel g45/g43 express chipset
directx 11
Looks like the issue is that image is stored in a location with non-ascii characters. Can you please check if preview works fine in cases when image's path is ascii characters only?
Also, is it only preview issue? Like does image appear if you're rendeing? In that case it might be cases by video driver issue which might not deal well with stuff like offscreen buffers. In that case you'll want to go to intel's download center and check for updates.
I think this is an issue with non-power-of-two textures. It also seems that this is using Microsoft software OpenGL, which is very old, the Intel drivers should support more.
sorry for the report guys it was just the driver version, i downloaded the latest intel driver and now it's working , thank you!! :D
Cool to hear this.
Thanks for the report, closing it now.
Sergey Sharybin (sergey) changed the task status from Unknown Status to Archived.May 21 2012, 12:13 PM
