.3ds importer doesn't do anything with the constrain_size
Closed, ResolvedPublicPATCH
Patch for: T31622
When importing a 3ds file from yepsketch.com the imported object was coming out way too big. I wanted to play around with importing objects using a scripts and found out that bpy.ops.import_scene.autodesk_3ds took a constrain_size parameter... but it didn't seem to have any effect. While digging through the code I discovered that the processing of this parameter is completely disabled.
I've attached a patch to fix the issue and a sample .3ds file which is scaled incorrectly for testing is attached to the bug.
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Resolved.Apr 3 2015, 12:44 PM
fixed, archiving.
