Marker deletion invokes strip deletion
Duplicates: T32009
OS: Linux64 Ubuntu, 2 nVidia GTX 560 ti oc, blender r48008
If you got a marker at a strips position in the sequencer and try to delete it by hitting x over the marker, 2 confirmation boxes appear: One asking to delete the strip, one to delete the marker underneath the first one...
Greetings, Thomas
Joshua, can you please look into this?
Not sure if it's possible to restrict sequencer's operator to not run form marker's "area" in sequencer, but workaround could be to add coordinate check to sequencer's delete operator?
Strange... everything it looks like the code used to handle these cases in the sequencer is exactly the same as what works in the other anim editors.
Right. And almost the same issue happens in dopesheet as well with the only difference that there popups are appearing one-by-one. But that's also kind of confusing.
Closed duplicate http://projects.blender.org/tracker/?func=detail&atid=498&aid=32009&group_id=9
Fixed in svn rev50242. Thanks for the report, closing now.
Sergey Sharybin (sergey) changed the task status from Unknown Status to Resolved.Aug 27 2012, 11:16 AM
