OpenEXR - no Z Pass
Trying for at least 1 hour to export any usable Z Pass. no luck
enable Z Buffer in OpenEXR does Result in a .exr with Image and Alpha, no Z Buffer.
Tried with/without "use Nodes".
Exporting Z Buffer to a separate OpenEXR gives Image with Z Buffer but probably no Z Distance Information. (Hooked up to Defocus Node looks similar as Camera Focus set to 0). not usable as well.
tried as well different combinations of Float Full/Half, Codecs
same in Blender r26461 and r28263M
thanks, bashi
btw, it would be great to be able to read/change Z Information (Focus) in Compositor. (differently than alter Z Image). Set Focus in Post makes so much more flexible as before Rendering. Re-Render to only set Focus Point to another Place? really? ;-) and sorry for placing this here.
Lukas, seems to be quite the same as http://projects.blender.org/tracker/index.php?func=detail&aid=31736&group_id=9&atid=498 ? Could you please check on this, thanks!
It's indeed a duplicate report, closing this one.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Archived.Sep 4 2012, 1:39 PM
