when rendering blender crashes.
Hi, first off i just want to let you guys know, that i like the program, it is give me the motivation to express my ideas, and also
it's free, thanks guys. And now for the problem, the problem is when rendering, anything over 100 frames, blender crashes
it saying blender has stop working, close program, here is my system info just to make things easier.
System Summary
Product Inspiron 531s
BIOS Version String 1.0.3
Service Tag H3GFPD1
Express Service Code 372-143-048-05
AMD Sempron(tm) Processor 3000+ (CPU:0)
Name AMD Sempron(tm) Processor 3000+
Cores 1
Threads 1
System Memory
Total Physical Memory 4.00 GB
Maximum Supported Memory 4.00 GB
Hard Drive - ST316081 5AS SCSI Disk Device
Model Number ST3160815AS
Firmware Revision 3.AD
Motherboard
System Board
Manufacturer Dell Inc.
Product 0RY206
Chipset nVidia MCP61
BIOS
Vendor Dell Inc.
Release Date 06/15/2007
ROM Size 512.00 kB
SMBIOS
Version 2.5
Processors
Cores 1
Threads 1
Signature 40FF2h
Family Fh
Model 13h
Revision DH-F2
Current Speed 1.61 GHz
Multiplier x 8.0
Features MMX(+), 3DNow!(+), PSE36, x86-64, SSE, SSE2, SSE3, NX
Cache Summary
L1 Instruction Cache 64.00 kB
L1 Data Cache 64.00 kB
L2 Cache 256.00 kB
Core : 0
Temperature 49 C
Threads 1
L1 Data Cache
Quantity 1
Level L1
Type Data
Size 64.00 kB
Associativity 2-Way Set-Associative
Line Size 64 bytes
Quantity 1
Level L1
Type Instruction
Size 64.00 kB
Line Size 64 bytes
L2 Cache
Quantity 1
Level L2
Type Unified
Size 256.00 kB
Associativity 16-Way Set-Associative
Line Size 64 bytes
Communications
Network Card - NVIDIA nForce Networking Controller
MAC Address 00:1a:a0:5d:6c:4a
Adapter Connected Yes
Current Speed 100.00 Mbps
IP Address 192.168.1.13
IP Mask 255.255.255.0
Gateway IP Address 192.168.1.1
DHCP Server 192.168.1.1
Adapter DHCP Enabled Yes
Driver Provider NVIDIA
Driver Version 65.6.5.0, 3-6-2007
Multimedia
Video Card - NVIDIA GeForce 6150SE nForce 430
Video Card Chip Type GeForce 6150SE nForce 430
Video Card Memory 64.00 MB
Video Card BIOS Version 5.61.32.25.2
Driver Version 8.17.13.142, 5-15-2012
thanks once again guys.
There's not enough information in this report. Please specify which operation system you're using. And what is more important, please provide minimal sample file which demonstrates the issue and steps needed to reproduce the issue.
Also please notice there's known issue when you're rendering an animation and 3d viewport is visible: http://projects.blender.org/tracker/index.php?func=detail&aid=29308&group_id=9&atid=498
So please try rendering using single window interface and set Render -> Display to Full Screen to check if you've run in the same issue.
For now marking as incomplete until requested info is provided.
here is a little bit more info, i thought i put this in there, but i guess not, i am going to try what you said, and i will let you know what happens,
thanks.
Operating System
Name Microsoft Windows Vista Home Basic Edition (32-bit)
Service Pack Service Pack 2
Build Number 6002
DirectX Version 11
Hi, i did what you said, i tried rendering in full screen, but it still crashes, so now what should i do? i set it for 200
frames and still crashes, and it crashes with PNG, AVI CODEC, AVI RAW, and I'm pretty sure
that it crashes with all of the output codecs, i hope the next update will fix this. thanks
To fix this we need to be able to reproduce the issue.
To reproduce the issue (as it was already mentioned in first reply) we'll need to have minimal file which demonstrates the issue.
No requested info provided in more than week. Would close the report until requested info is provided.
Things to be tested:
- Try upgrading video driver (there were some crashes on linux caused by multi-threading related issue in nvidia drivers, the same could be in windows drivers as well)
- Try to reproduce on other system (to figure out whether this issue is configuration-specific)
- Try downlaod opengl32.dll from http://download.blender.org/ftp/incoming/softwaregl/ and put it near the blender.exe. It'll switch blender to software opengl mode, which would make interface slower but would help figuring out whether the issue is indeed related on driver/video card.
Sergey Sharybin (sergey) changed the task status from Unknown Status to Archived.Jul 13 2012, 1:32 PM
