Blend crashes Blender on load.
This object is from a much larger mesh that now crashes blender when trying to load. There is no warning, no crash log, nothing. I checked other parts of the mesh and it seems this is what is causing it from loading.
This blend will load on Blender v2.63a
System:
Blender 2.63 r48820
Win XP SP3
2GB Memory
Single core CPU AMD Athlon 2
Brian
PS this model started life in Blender 2.48
Brian
Confirmed.
From a quick glance, it seems the problem is caused by a nodal material… But if someone can explain me how such a backtrace is possible, I would be happy!
Program received signal SIGSEGV, Segmentation fault.
0x00000000021e94a2 in dag_add_material_nodetree_driver_relations (dag=<error reading variable: Cannot access memory at address 0x7fffff7fefe8>,
node=<error reading variable: Cannot access memory at address 0x7fffff7fefe0>, ntree=<error reading variable: Cannot access memory at address 0x7fffff7fefd8>,
rootma=<error reading variable: Cannot access memory at address 0x7fffff7fefd0>)
at /home/i7deb64/blender-2.5-svn/__work__/blender_msgs/source/blender/blenkernel/intern/depsgraph.c:356
356 {
(gdb) up
#1 0x00000000021e960c in dag_add_material_driver_relations (dag=0x6c4d7c8, node=0x86ad7b8, ma=0x877a9b8)
at /home/i7deb64/blender-2.5-svn/__work__/blender_msgs/source/blender/blenkernel/intern/depsgraph.c:393
393 dag_add_material_nodetree_driver_relations(dag, node, ma->nodetree, ma);
(gdb) print dag
$1 = (DagForest *) 0x6c4d7c8
(gdb) print node
$2 = (DagNode *) 0x86ad7b8
(gdb) print ma
$3 = (Material *) 0x877a9b8
(gdb) print ma->nodetree
$4 = (struct bNodeTree *) 0x877b088
…How can a pointer be valid in the caller and invalid in the called func???
Bastien, that's simply stack overflow issue -- no space left in the stack to store function parameters.
Joshua, that's a regression initially introduced in 48515 and later tried to be resolved in 48687. Afraid the only way would be to use LIB_DOIT flag for materials which have been already handled there.
From a second look i could see issues in this area was already reported: http://projects.blender.org/tracker/index.php?func=detail&aid=32017&group_id=9&atid=498
Please move all the feedback there.
Sergey Sharybin (sergey) changed the task status from Unknown Status to Archived.Jul 12 2012, 9:13 AM
