Fix compilation with boost 1.50
Closed, ResolvedPublicPATCH
Boost 1.50 removed filesystem v2 so we need to change some stuff. It is safe to remove the definition because v3 has been default since 2011. If you care about deprecated distributions, maybe you should also add a precompiler check against BOOST_VERSION.
Commited to svn rev48836. Thanks for the patch!
Sergey Sharybin (sergey) changed the task status from Unknown Status to Resolved.Jul 11 2012, 4:49 PM
