Crop and offset coordinates changes proxy render settings on image strips
I'm using blender as Video Editing software with some images strips as input (rendered PNGs from other blender files).
The problem is that setting Proxy render to anything different than 100%, gives inconsistent results in the preview: it is like the coordinates set up at full resolution are not being scaled to the preview size, but just calculated as absolute coordinates. So if i crop/offset a strip at 25% preview size, then in the final rendering i get unexpected results (the strip is not present, or just it placed not where it should be), and vice-versa: if i crop/offset at 100%, then i can't preview the movie at 25% because the PNG strips remain too big.
This does not happen if i offset/crop an effect strip, such as a Color one, for which the proxy preview is rendered correctly.
This is a huge issue because it's hard to sync audio and video if working at 100% with the preview being too slow.
Using Blender 2.63a on Windows 7 64bit, Studio XPS 16 (Core 2 Duo, Ati RV730, 8G DDR3, Catalyst 12.4).
Same issue on my friend's 13" MacBook (OSX, Core 2 Duo, Nvidia graphics).
Fixed in svn rev50901. Thanks for the report, closing.
Sergey Sharybin (sergey) changed the task status from Unknown Status to Resolved.Sep 26 2012, 12:40 PM
I've commited other fix to svn rev52629 as a fix for report #33295. So probably you'll want to double-check there's no regression here.
