Not sure this is a bug or simply a limit of the vector blur, btw I'm posting it just in case:
The outline of the moving object is jagged (pixeled?) by the vector blur, see the attached image (and blend).
Ubuntu 10.10 64 bit, r49166.
Comment Actions
rev49214, no optimizations
xubuntu 12.04
pentium M 1.7 GHz
2 Gb RAM
ati 9600 (open source drivers)
Comment Actions
You should either render sky on a separate layer or enable FSA.
Not a bug, just how vector blur works.
Comment Actions
Right, thanks.
Btw, I attached a new image showing that, with "Full Sample" enabled, the render is correct in the render output but still jagged in the viewer.
Comment Actions
When compositor is calculating image for interactive interaction it's not doing FSA filtering and only using single buffer for all calculations, that's why viewer node is still looking crappy. In theory compositor could do FSA too, but it'll make calculation several times slower.
