unstable z-buffer or z combine composition node
Blender 2.63, 2.64 test builds and SVN head( in the freestyle branch)
Linux/Ubuntu 12.04 64 bits
Nvidia
I've noticed a really annoying bug related with zbuffer, however I have not been able to isolate it.
When you are using a few layers with zbuffer and/or z combine composition node the composition results(renders) are not stable.
This behavior can happen during the render of an animation, or if you simply press F12 a few times.
However those results are not purely random. In the attached file I noticed two possible results, but in other production files I noticed up to 4 (maybe 6, but not sure) different results. Maybe the number of different results is related with the number of layers used in the composition.
I think the problem is in the Z output of the RenderLayer nodes. But I'm just guessing.
Attached the blend file and 2 possible results I got pressing F12 a few times.
Steps:
Open the file, press F12 wait for the render. Press again F12 and wait for the render. Repeat until you see a different render. Patience, sometimes I had to repeat the render a lot of times.
Looks like 2.63.4 (r 46401) works fine. I've done around 100 renders with identical results.
Fixed in svn rev49496. Thanks for the report, closing.
Sergey Sharybin (sergey) changed the task status from Unknown Status to Resolved.Aug 2 2012, 12:20 PM
